Gruz7
North Smithfield, RI
Nothing really to the Expy today... got undercoat for the rockers/rad support for this winter just to hold things together (lol)... and tonight I helped my buddy with a 7.3 build a sled deck/ramp for his skidoo.
ManUpOrShutUp
Ironically enough that is actually what's in there right now [emoji1]
Sent from my SAMSUNG-SM-G890A using Tapatalk
That's what I had in mine and at half its rated lifespan it was pumping out half it's rated CCA. The dealership asked if I wanted them to replace it and I laughed. Now I've got an Advance Auto Gold in there (made by Johnson Controls).
Habbibie
Is it Christmas yet?
Chicago
Nothing to the expy more like to myself now, when you're lacking some serious sleep you make idiotic mistakes like I just did I grabbed a lid of a tin can and spun my hand on it like a moron now I have 4 sliced fingers bleeding all over the place.
whitelightning99
Pa
I went to the junkyard today got a few relays/fuses,an alternator,signal switch,belt tensor and a complete fuse box that someone already had taking out,got home tired my relays for my
"no signal issue" well all 3 didn't work,felling bummed out,So i just moved on to changing out my noisy alternator to the junk yard remanufactured one plus the belt tensor cause it was sticking after about and hour had it all back together BUT when i got in it and turned the key the engine slightly turned over and all the lights on dash everything lost power, i tired it a few more times same thing,well thinking the battery went dead i pulled the battery charger out after about 10 mins of charging still did the same thing so i decided to turn the key on and jump the solenoid with screw driver and it fired right up after it was running for few mins in the dark with my phone flash light app I saw what happen while i was pulling the alternator out i pulled on alternator wire a little too far and pulled this little wire off the solenoid it just pushes on there and it's protected with a rubber boot.
Had me worried for about 15 mins thinking here we go again dam Ford, but nope "dam mechanic" hehe
