creef14
VA
Replaced door speakers and now replacing rusted out brake lines to the rear wheels.
Probably going to do HIDs tomorrow. Still trying to figure out the ballast placement and wiring with the rubber gasket on the 2nd gen headlights.
whitelightning99
Pa
Took the grill out of the surround piece. Goona try to come up with a way to do a custom insert WITHOUT chopping the dam thing all up like those "RBP Grills" they install on these new trucks BUT that's the look i am going for.Since they don't make em for 1st gen Expo/F150 at least i havent seen any.I want to try to build my own grill to fit over the stock.if i ever decided to take it off the original grill would still be there intact Not all messed up.like it was never on there.That's the plan anyway!!
whitelightning99
Pa
This is what i was going for.I like it.Don't care if you old men don't *****
ExplorerTom
Colorado
Is that photoshopped? Looks pretty sweet. $500 or so from T-Rex is a lot for a grill insert IMO.
whitelightning99
Pa
yes and thanks man 3 hours spent on "paint" then almost another hour spent on a photo editing web site hehe
yea i can't see spending that much on a dang cheap made grill insert.that you have to mangle your grill to get them install, i seen them things and there flimsy as f$$k not worth the money more less paying for the name i can make my own for around 40 bucks or less and look just as good and it won't be no flimsy POS
whitelightning99
Pa
Took the throttle body off, cleaned it, it was filthy nasty inside mostly the back side and back of throttle plate,also took egr valve off cleaned the carbon out of it, Sprayed the mass air flow sensor,while i was at it i painted a few rusty looking bolts "black" and all bolts that i took out i put some anti seize on em.Also put a zip tie around the throttle cable inside up by gas pedal that "took some slack out of cable" only needed one, Honestly i felt a difference right away as soon as i took out of the drive way and got on the gas a bit
Hampton, VA
I finished up relay switch for amps
Mr. 10K
whitelightning99
Pa
Took back wheels off today,Took calibers and rotors off cleaned and sprayed all the moving parts in there very little bit of wd-40 got the e brake cable and stuff to work better still sucks though lol. BUT found the right rear axle seal has been leaking for some time every things caked and soaked with gear oil.So axle seal will be needing to be replaced uggg
cman1120
Colorado
Looked at it in my garage again and need to get around to replacing the battery and wash it before winter.
Edit: Have no idea why it went in sideways
Sent from my SAMSUNG-SM-G890A using Tapatalk
tifanydire
