Looks nice Dennis.
I've seen a soft buffing conical cylinder that you can attached to the end of cordless drill that allows you to get in the corners. I just can't remember where I saw it now.Thank you Andy. Im look at buying some micro fiber pads to help get in those corners, so my finger dont have to work so hard.
Maybe these.
You sir got alot of knowledge on this matter [emoji2]
Nice to see someone that can help me in the correct direction.
Everything that I have learned so far is from watching countless YouTube SAS Swaps.
And reading in the 4x4 Pirate forums.
So much so that I know I can do the conversion
Everybody well most people tell me it can't be done or it's a wast of money just go buy a 78 Ford complete running and fix it up.
Well that's a option also BUT it's not what I want to do. I know it can be done on this 04 Expedition it is not much different than doing a 97 Chevy 1500. I'll be doing front and back conversion vs just the front.
I've found a few 78 Ford trucks complete and running on Craigslist for around $4000 to $5000
While trying to find some axles.
I mean how many 04 Expeditions do u see rolling around on Solid Axle Swap..haha
That's one of the reasons why I want to do it to mine and second I love my Expedition.
Now the only thing I'm not sure on is weather or not would I be best to run coils and shocks all around or leafs in back and coils n shocks n front or leafs all around ?
The main goal is that I want articulation/flex
For trails and having fun when we go to the Mud Fests through out the year.
Or possibly 3 link the front and 4 link the rear would give me the most articulation .
But this is going to remain my daily driver afterwards also so I can't be going to crazy..lol
And I'm pretty sure that the rack n pinion steering is gonna have to go ??
As u said a gear box.
The Dana 60 and the 14 bolt are both under the 78 Ford ?
For some reason I was thinking that the 14 bolt was under a Chevy early 80's.
But the Dana 60 axle for the front I knew that I needed but the rear Axle I was unsure of.
But I'll look for a 14 bolt rear also now that u have pointed me n the correct direction.
Thanks for sharing your knowledge with me it helps a lot when someone isn't as knowledgeable in this conversion.
Thanks again brother
Sent from my Nexus 6P using Tapatalk
That looks nice Scoot!Well finally got the bumper ready . Next is mating it up to the frame. But that's on hold bc my wife is working weekends now and I don't want to try it with my 4 year old daughter running around in the shop. So this is it's new resting place for a couple weeks.
But today I also got the accent flood lights or whatever they are called I can't remember..
Installed at the bottom of the doors and tied the wiring into the puddle lights in the door side mirrors. I'm gonna rock them awhile to make sure I like them if so I reckon I'll get some for the rear doors.
New front badge, MAF cleaned, intake cleaned, air filter replaced, throttle body cleaned a bit, thermostat replaced
