Hamfisted
I re-read your initial post. The part about the gear shift lever not unlocking. It might be worth taking a look at the ignition switch itself. I didn't see that mentioned in what you had done already. I mean the electrical part of the switch, not the keyed part. You can take the top and bottom off the column and you'll see it. It's directly across from the keyed ignition switch. Pull the plug off and try jumping it and see if at least the dash lights come on, or you can unlock the gear shift lever as you normally would (brake depressed....) . Then you can try to bump the starter from there. The switch is only about $20 at Rock Auto to replace. You tried swapping in another relay into the PCM relay slot right ?
Here's a link for the 03/04 service manual if you don't have it already:
https://spaces.hightail.com/space/hoVVsN5P2A . The ignition switch is discussed on page 754 or thereabouts ....
https://www.rockauto.com/en/catalog...l-switch+&+relay,ignition+starter+switch,4700
