2nd alt 12v hookup
Hampton, VA
OK my electrical gurus...I have a 2nd alt for install in addition to what's already on the truck...this is to run my stereo system...right now it's setup to run accessories so I need a good 12v source to connect to besides the battery...any ideas? It has a small yellow wire for the source but I don't know what will be the best place to hook up to...I will be adding 2 runs off 1/0 ga to battery which is why I specified not to battery...
Mr. 10K
stamp11127
Temple, Georgia
It sounds like you want to connect a distribution block to the battery then branch the various circuits off of that.
Hampton, VA
No...I'm wanting to give the alt a 12v source besides the battery...wire needs 12v ignition source...unless you're saying take it to the battery? It's to run accessories which are my amps
Mr. 10K
dfk70
Florida
I don't think that you want to run equipment directly from the alternator. Too many fluctuations in output. Better to run off a battery that the alternator charges.
Or maybe I'm not understanding the question. :Big Laugh:
Hampton, VA
They will be ran off a secondary battery...but the alt needs power to maintain battery voltage so it needs to turn on...when it turns on it will charge the secondary alt which will provide the power for my amps
Mr. 10K
dfk70
Florida
Probably have to find a switched 12V under the hood. Sorry I can't help more.
stamp11127
Temple, Georgia
The voltage regulator inside your 2nd alternator must be connected to the battery or battery bank you will run the amps off of. This way the vr will know when to turn on and charge the battery(s).
All you need to do is wire just like primary alternator but using separate circuitry. The only common connection will be the ground unless you want to run an isolated ground which will be a little more involved, but can be done.
What is the 2nd alt rating? What is the total wattage of the amps?
Habbibie
Is it Christmas yet?
Chicago
Stamp there's so much work involved with adding a second pulley driven component. Find a spot for it along the belt, make a bracket to hold it in place while maintaing proper alignment. Then wiring the entire new system in series with the existing alternator. There is higher amprage alternators on the market, one of the 2nd gen expy's at my company has a 200A alternator.
