ExplorerTom
Go bigger. That one is roughly the size I have and wish I would have gone bigger.
I had to go into settings from the home screen and I think the next step was 'manage extra PIDs/Sensors' and it'll pull the information specific to Ford.Yes here's a screenshot of the Torque app showing Transmission fluid temperature
Assuming I'm in the correct place n the app to read Transmission temperature?
And I do have the Pro version of Torque
And this is the cooler that I'm looking at as it got alot of good reviews
Will I need to order any special connection for this cooler ?
Sent from my Nexus 6P using Tapatalk
Ok yes I know exactly where your talking about..HahaI had to go into settings from the home screen and I think the next step was 'manage extra PIDs/Sensors' and it'll pull the information specific to Ford.
Would this work in a 2008 or is it only on newer models?You can get a Scan Guage which plugs into the computer port under the dash. It will tell you the trans temp and three other readouts. I have been using one years. No muss no fuss installation. A little bit to set up, but it does a lot. Also will read out other codes.
