Drywall Screw
sprman4lissa
Newton, IL
I have a 98 Expedition and my rear driver door will not open from inside or out.. It use to open but today my son shoved a drywall screw in the child safety lock do dad and now it won't do nothing and it seems like it's still locked... i have door panel off but still can't get to child safety thingy to try and get screw out.. will taken the outside door handle get to it? Any suggestions would help alot... Thank You
FordandPolaris
Saint Cloud, MN
Can you see the screw at all? Pen magnet might be able to get it out if it isnt jammed down in there. I am not too familiar with the child safety lock itself but can you see one of the bars that control the handles leading towards that?
FordandPolaris
Saint Cloud, MN
Does that plastic surround on the child lock pop out? That might allow you to see in there better...? I think you might be the pioneer for this problem haha.
stamp11127
Temple, Georgia
That reminds me of some of the stuff my son "helped" me with when he was younger....
From the latch assemblies I've seen on the Ford vans, taking the outer handle off will not help at all. Is there a cable going down to the latch or did they use rods?
If they used the cable, I'll take a pic of the latch assy and post it here.
sprman4lissa
sprman4lissa
Newton, IL
As far as i can tell they are rods... to me the door seems locked and the screw is stuck where it unlocks the door through child safety thingy.. the door lock won't hardy budge either way if that makes sense
mpsjr
Baton Rouge, LA
You should be able to manually move one of the rods up/down to open the door from inside the truck with the panel off, even if the handles are off. One rod locks/unlocks the door, and the other will open it. You might have to push down on it (or, alternatively, up) pretty hard to get it to open the door, but it should work. Typically, you have to move the rod in a downward direction to open Ford doors. Make sure you're holding pressure against the door so that if you do manage to get it to release, it will open.
sprman4lissa
sprman4lissa
Newton, IL
well i tried what you said with the rods but no luck. i think screw is stuck on the door lock part inside. just enough not to let it unlock it... i don't know what else to try.. might see what a body shop could do tomorrow.. i'll keep you all posted
sprman4lissa
sprman4lissa
Newton, IL
well i started fresh this morning and my door is fixed.. I had to take outside door handle off on the outside. Bam i seen the light and boy was screw stuck in there but it took awhile but it came out. It was a 3in drywall screw. I fixed the child safety do dad on both sides so the don't lock & made a stainless plate & shot some flush self taping screws and painted it to match my ride. so i will never have to go threw that mess again. Thanks for all the help & info
MUSTAFA4072
