96mustangV6
Well lately my Navi has been givine problems with the A/c & Heat.
When I get in and start driving I'll hit the A/C. Sometimes it will blow ice cold and sometimes heat. I thought it was the a/c compressor or low on freon but both check out great. When its blowing heat (while on max a/c and temp on 60) if I switch back and forth between vent and max a/c. After a few times it will Start blowing cold.
The other day if was cold goin to work so o turned heat on and it was blow in a/c ( while it was on vent and temp on 90). I did same I would turn it off and back on 4-5 times then it would start blow in heat. I could have sworn that one time it made a clunk under dash once i t did this. Like a door was closing. The rear air works perfect though.
Starting to irratate me. If its blend door where is a how to on how to fix it and how much. I was thinking maybe its the climate control box but not real sure.
