New to me, 1998 Ford Expedition XLT
T
Tcm glx
Small update, swapped the Michelins for a 285/70/17 Yokohama ATS. So far loving it.
IMINYOURCHAIR
Altoona Alabama
duuuude I have been eying a retrofit but I just keep backing out not knowing all of what I will need. if you could post what all you ordered for that to work, that and a front angle pic showing both headlights
T
Tcm glx
Sure, I have been doing retrofit for about 3 years now as a side hobby. I started doing 92-96 Ford Bronco/F150 and then expanded. I've done about 300 retrofits now include F150, Lightnings, Superduty, and some VW stuff.
For the Expo, I used a pair of Eagle Eyes replacement headlights with clear corners, similar to the OEM lightning style. I used Morimoto MH1 bixenon projectors, and Xentec 55w bulbs and ballast. Works great! I'll have to take some more pics tomorrow. I need to adjust the height about 1/4" on the drivers side but it is so much brighter!! it isn't expensive to do, you spend about $225 or so on materials.
IMINYOURCHAIR
Altoona Alabama
Nice. What I got stuck on was the harness and projector I wasn't sure of what would fit in the housing and look good to boot
T
Tcm glx
Super easy. The MH1 fits, very tight, but it fits. Shrouds have to be big, but not deep. Harness is a 9007 harnes so that it is plug and play.
T
Tcm glx
I used the orbit shroud. Modified it slightly to go in deep enough.
I use the 9007 hi low harness from EBay. PM me and I can walk you through it.
IMINYOURCHAIR
Altoona Alabama
actually that's all I needed info on. I will put the order in maybe in mid feb or early march when I get the spare cash saved up. did you get all your stuff from TRS or did you shop around to get a lower price?
T
Tcm glx
Living this truco so far.
Question guys, pulled out the stock stereo and CD changer, are these things worth anything?
T
Tcm glx
Been a while since updated.
Truck has been great so far. Selling the Yokohamas, going to a BFG KO2. Big BFGS fan so going to yank these Yokos off and swap out. Also added a KN Intake. Like the sound. Can't really tell if there is anymore power. Added the clear fog lights from DEPO as well.
Here are some pics on a recent trip to Ensenada.
***** Banda
LED bar test fit
Mediamonkey11
Enumclaw, WA
Sorry I'm just now seeing this, but great work! I too did the retrofit but used Morimoto D2s 3.0 due to the fact they were cheaper when I bought them as introductory pricing. I was surprised how easy it was to do overall, even though the shrouds needed slight modification. I also used different headlights, Ill post pics when I get home!
Mediamonkey11
Enumclaw, WA
I used the gunmetal(?) shrouds from thereteofitsource.com, great site! Had to shave flat spots on top and bottom of it to fit in the housing though... Sooooooo much better light! Especially because I used 5k hids with 55w ballasts.
