30" Light Bar
Otters07
South Carolina
One of my truck sponsors is offering Hanning LED Bars and want to get one for the expy since its now the "road trip" vehicle. I have a 20" Rigid Industries on my F150 but have enough room in the expy for a single row 30" he offered to send me.
I guess my question is what would it take to mount one of these bad boys in there? Has anyone done this? Im looking at the opening in the bumper either top or bottom slot or would it be best to put behind the grill?
Hanning 30″ Single Row LED Light Bar | Boost-Bars
Otters07
Otters07
South Carolina
Well got my light bar. Planning to mock up this weekend. Guess I will do a write up since nobody else had done this before...
k9education
Looking forward to see what you come up with. I was planning on getting a light bar in the future, but wasn't quite sure what to mount it to yet.
I can provide a write-up based upon my experience.
I live in a suburban area and often drive in rural areas nearby. The "fad" now is for pickup truck owners to mount this type of light bar near the front license plate bracket area, then drive the trucks at night with the headlights turned off and the parking lights turned on. They operate with the light bar illuminated which temporarily blinds oncoming drivers and often is not focused properly. I have no doubt this operation violates State law, but have never seen one of the vehicles stopped.
I hate the light bars because they are blinding to oncoming drivers and can not be focused properly like the 2 / 4 factory headlamp systems.
I own a 2015 Expedition Limited 4x4.
k9education
They'd nail them for that here.
I'm considering one for use on state/national park lands. I hike late and usually don't see a single car for a good 30-40 minutes (until I hit the interstate). The wildlife are coming from all directions at that hour though, so I could use all the light I can get.
Otters07
Otters07
South Carolina
Yeah I am adding this for dark country roads but NOT in place of headlights. Mostly to help with deer and other potential roadkill and save the front end. Most are "offroad use only" anyway except on my F150 I have the Rigid Dot Approved Dually lights in place of my factory fog lights. They are bright but have a super focused beam with a projector style cutoff to keep from blinding other drivers. I use those on the roads with no problems...now the 20" bar on the truck. Nada. It would burn drivers retinas out it's so bright :naughty:
Chris_H
WI
I attempted to get mine mounted higher, but the frame rails offered very solid mounting points. I have it wired so it is on with the high beams.
Otters07
Otters07
South Carolina
Would you mind sharing some pictures of how you mounted? That's exactly where I want to hide this one.
Chris_H
WI
Mine is a soye 240W bar that I believe is about 26" wide overall, and the mounting tabs fit onto the rails and I bolted in place. I'll try to get a photo.
Otters07
Otters07
South Carolina
My Rigid Industries on the F150 has side mounting tabs but this one has adjustable mounts across the bottom. Thinking of running a plate or strut across the frame and just attaching to that.
RedExpy
Kansas
Chris, were you able to get a pic of the mount? i want to do one for mine but have been perplexed on how to mount it.. looks great!!!
Chris_H
WI
I just went out to the garage and took a few photos. The first is looking down at the top of the bar, taken through a grill slot. Second is a close up of the end of the light bar, and the third is from under the Expy looking up at where the bar is mounted.
I would have preferred to go higher, but it is really quite effective where it is.
The photos didn't import with correct orientation. You may need to use your imagination. On a fairly old Macbook, if I select open attachment in new tab, the images show correctly. YMMV
1111ExpyEL1111
NW Wisc.
Chris,
Where did you buy this from? Can't find any sources via Google but I'm probably just not doing it right.
1111
Chris_H
WI
I bought it directly from the manufacturer.
http://www.gzsoye.com
Chris_H
WI
I sold the Expedition and bought a more appropriate tow vehicle. If anyone is interested in the light bar I used on the Expy, I'd probably sell it. I'm not sure I can mount it on the new truck.
toadeyes
I'm about to buy a 30 inch curved LED light bar any idea if it would be more easier to install the thing compared with the traditional straight bar?
Otters07
Otters07
South Carolina
What kind of truck did you get?
Otters07
Otters07
South Carolina
Wish I could answer that but I have still yet to find the time to install mine. Looks like I will try and remove the grill to apply a vinyl wrap here soon and will stick it back there while I have that off.
