Hmm, I certainly suppose that's possible. I'll have to pay more attention now on the road for XLTs to see if they have DRLs activated.
I'm not sure about the HDC. I don't have it since mine is a 2wd truck but I do know there is a physical button for it to the right of the steering wheel. Do you have an option for HDC in the screen too?
In regards, to the VIN, seems correct. You can check your VIN to verify using line 726-44-01. The line should look like xxxx xxxx xx. Let's say it reads 3131 3933 34. Separate these into pairs of two as in:
31. . . . .31. . . . 39. . . .33. . . .34
These two digit numbers are your hex numbers.
Use this chart and covert the hex numbers into characters.
Hex 31 corresponds to a Character of 1
Hex 31 corresponds to Character of 1
Hex 39 corresponds to Character of 9
Hex 33 corresponds to Character of 3
Hex 34 corresponds to Character of 4
so the last five of the VIN would be 11934.
Also I find Canadian VIN numbers using CarGurus Canada. Works like a charm:
https://ca.cargurus.com/
