15-17 LED Headlights
J_82
Eagle Pass Texas
I am thinking of changing my OEM halogen headlights to match the rest of my leds white lights.
What’s is yalls experience with LED Headlights?
I have used white halogens on other vehicles and they are ok and reliable if you stick to a good brand. I have never used led headlights though.
gixer2000
Retrofit or Bust
Massachusetts
I'm just copying this from the other thread you asked about led. This thread can get hairy pretty quick so strap yourself in
leds are not designed for a reflector or halogen/hid projector so they look good but ultimately cause even worse night time vision. Plug n play hid have the same issue but they out better light down than a pnp led does. Either one will cause light scatter and possibly blinding oncoming traffic. Even aiming them lower does not rectify the issue even though some may say it will. Lowering them Just cuts back in your distance and in some cases gets the scatter below oncoming traffics eyes
gixer2000
Retrofit or Bust
Massachusetts
One thing that I forgot to mention is that diode Dynamics is getting ready to release an LED bulb that is designed for a reflector housing and will maintain the original beam pattern
J
J_82
Eagle Pass Texas
Also I am not opposed to using white halogens since I can buy them at any of the big chain auto parts stores and have warranty if they go bad.
gixer2000
Retrofit or Bust
Massachusetts
The funny thing about white halogen is they become white by using tinted glass. What are you gaining? Color and less vision. I'm sure people will argue with me on this but it's 100% truth
J
J_82
Eagle Pass Texas
They are design to produce more light.
Can you prove the only thing you gain is color?
gixer2000
Retrofit or Bust
Massachusetts
Do I need too? Same wattage through tinted glass so it should speak for itself. Even if that tint is blue it's still tinted and affects light output the same way a smoke tint does. I'll dig up some actual information for you. Give me a few
gixer2000
Retrofit or Bust
Massachusetts
The only upgrade that's still a halogen is the Phillips extreme vision or osram nightbreakers. I'm on the search for some actual lux readings of oem vs tinted glass bulbs.
Adieu
SoCal
LEDs : easy enough to get comparable-to-halogen or better output and has been for a year or two... challenge today is getting comparable-to-HID output
Adieu
SoCal
What warranty???
Some of the Sylvania bulbs are literally LABELLED as "service life : 65 hours"
Have fun warranty claiming THAT
J
J_82
Eagle Pass Texas
Wattage can be misleading to those who do not understand electricity. Wattage is just energy consumption. Aftermarket bulbs have to stay within the OEM wattage because the wiring and the whole system is rated for such. So they don’t want be responsible for damage to the system. You can produce more lumens with a same wattage bulb or even less.
gixer2000
Retrofit or Bust
Massachusetts
Tell me about this trickery you speak of... So same voltage, same wattage generating more lumens yet still through tinted glass.. Are They using some other type of gas within the bulb capsule? Please explain how they are boosting the efficiency of these bulbs.
In most cases they'll boost the wattage of the bulb because they dont give a damn about your factory wiring and typically would come with a warning that pretty much covers them. Remember who your dealing with 90% of these bulbs... China
Just saying. I'm still searching for the lux chart one of the guys from headlight junkies did but struggling to find it
Also I have no clue how electricity works. Couple pics from what I do every day as an fyi
J
J_82
Eagle Pass Texas
You almost answered your own question. If you can’t change voltage and wattage what can you change. No trickery just basic electricity. I think, I am not a electrician.
Those pictures are cute, what is that some kind of low pressure fuel module? Just wondering I think I have seen that before.
gixer2000
Retrofit or Bust
Massachusetts
Well what are they changing? You can either boost voltage which will reduce bulb life but lower amperage, boost wattage which drives your amperage(current) up, also increases evaporation of the gas within the bulb reducing bulb life? The only other thing they could really do is change the gas type (if there is another option because I'm not sure there is).
I'm actually an HVAC service technician. I basically troubleshoot electrical/mechanical systems all day long. The pictures I posted are of a power/control system in a Titan Air direct fire make up air unit. Modulating gas valves to maintain an 90° rise with 80% outside air at all times. Really awesome equipment. I'm actually the rep in my area and do all the startups/service
J
J_82
Eagle Pass Texas
You are on the right track.
Some of the changes make for a shorter bulb life. These “white “ light bulbs are know to have a shorter life but they are brighter. And no you can not change voltage with a simple bulb swap. But enough of that maybe you can be of help on the LED lights. I would like to know what are people’s experience with LED bulbs on their headlights.
07xln
Dallas
I thought you were an Optometrist
I don’t care what Gixer says. I run LEDs on my 17 EL and love them. They’re a night and day difference from the oem halogen bulbs. They put out more light and further light down the road. When facing a wall beam is still the same as the oem bulbs. Not one person has flashed me yet which is usually tell tell if you’re blinding them. I don’t have any trouble seeing at night with them on either (still trying to wrap my head around that one)
J
J_82
Eagle Pass Texas
Do you mind sharing which lights you are using? I would like to see more info on them.
Also how long have you had them for?
07xln
Dallas
I’ll have to dig back through my Amazon orders and find them. I bought two sets because the first set I got was the wrong wattage and to dim.
I’ve been running them for 6+ months at least.
