Hello all,
I picked up 2007 Expedition EL Limited to replace a 2009 Expedition Limited that was totaled by a driver that ran a red light, and I have questions regarding headlights.
- For those that have done HID projector conversions, what route did you choose?
- Is it possible to convert using OEM? (2015+ HID headlamps)
- If an LCM change is needed or recommended, is it better to use the LCM from a 2015 or from a ~2007 Navigator?
My preference is to stay as OEM as possible, and avoid the "tuner" look. My BMW's will be the only headlights with rings.
Additional questions:
- I've seen that it's about $500 to add the required lines and coolers for the heavy duty tow package? The EL has a the 3.73? rear end standard, so that shouldn't need to be changed.
- Has anyone used any of the idatalink products for remote start? I'm looking at this for its integration into aftermarket head units, specifically an Alpine X208U.
Of course, this all comes after the standard work of:
- Plugs
- Fluid changes
- Trans flush (82K miles)
- Tires
- Brakes
Thanks,
~Mr Shank
- Plugs
- Fluid changes
- Tires
- Brakes
Thanks,
~Mr Shank
