5.4L Timing Chain Set; CLoyes or Ford OEM?
11b4v
Alabama
09 Expy EL, busted, just now started on the tear down but haven't got eyes on yet as exactly what broke, but thinking its the right side tensioner/guide popped/cracked the valve cover. There was no catastrophic failure and it limped a mile before being parked.
I'm going to use a the high flow Melling oil pump and am leaning on the Ford timing chain replacement set.
Before I pull out the credit card, what's the thought on the Cloyes offering?
coolzzy
Idaho
How many miles at point of failure? Use the ford parts or you'll be tearing it down again. Check out the F150 forums and see it's a common reoccurence if you use non Ford parts. Pay the little extra and keep it oem, the new parts have been revised several times since 09.
Boose
2017 Platinum EL
NJ
I replaced everything on my 05 at 100K as a preventative exercise. The damn thing sounded like a diesel... I too did the Mellings pump, but I was tight on cash and used all aftermarket timing parts with no problem. I traded it in at 148K still as silent as it was after I put it back together.
1955moose
Well from what I've just read about fitment issues on various different vehicles, I'd say pay the diff, and go with Ford. It never ceases to amaze me how an aftermarket manufacturing company can have the Ford part right in front of their mug, copy it, and screw something up! It's too thick, too thin, the tightness on gears is wrong! Theirs interference with the block, something. It seems that if your making a clone of a part, then clone it. Nah go with Ford part, online theirs a lot of places to order from to save a $.
johnboneske
I have a brand new set of guides, tensioners, chains, pillows, etc that I would send you for A Lot less than you can get it for.
11b4v
Alabama
Johnboneske, sorry I missed your post, that would have helped.
Can anybody advise me the orientation of the Ignition Transformer Capacitors for an 09-10 5.4L?
the black plastic square with a notch missing and a wire protruding.
thanks, mv
BillAlex
Mesa, Arizona
John, Do you still have the brand new set of guides, tensioners, chains, pillows, etc. I would have PM you but haven't figured it out yet. Thx
johnboneske
I do have the set still. I will send you a PM with my phone number
proftomda
georgia
I used a Cloyes timing chain set, Motorcraft steel ratcheting tensioners from the earlier 2 valve engine, Motorcraft phasers and a Melling oil pump. That was 3 years ago and it purrs like a kitten.
WEDGE
Kimberley BC Canada
I used Cloyes timing components and a Melling oil pump. It's been two years now and no problems. Locked out the phasers too.
Franklin Jones
Nebraska
Last year I used a Cloyes set on my wife’s Buick. Chain stretched within a year.
Spoke with my local mechanic - only one I trust, lets me provide my own parts, doesn’t fix more than I need, etc - and he reported that Cloyes used to be quality, but that has really diminished over the last 2-3 years.
I’d stay OEM on this one.
TobyU
Cloyes certainly use to be as good as you would even need, usually better.
Now, a lot of brands---I'm talking to you MOOG--- are not what they used to be.
Made in China by someone this year and who knows next.
The quality control usually consists of "Yep, that's a timing chain"
TDGFordGuy
Bay Area, CA
He's not talking a cloned part from autozone... Cloyes make timing chains they claim to meet or beat OEM spec & quality. does anyone know? Price is about the same vs FoMoCo parts.
max78
AZ
Just to bring some more life into this thread.
I have a full Melling 3-391SCC kit. It comes with ratcheting cast iron tensioners so there is no longer any possibility for them to blow a seal, or get slack. Ratcheting tensioners are fine for this application. They are only an issue on high HP manual transmissions where the chain can whip with aggressive gear changes.
I paired that kit with a Melling 360HV high volume pump.
Looking at all of the Melling parts compared to the originals that came off. I would go with the Motorcraft (Ford OEM) everything, but get the Melling cast tensioners. The Ford chain looks a lot stronger than the Melling ones. The guides were identical, but I still prefer OEM.
I did install the complete Melling kit however and have not had a single issue to report.
I have used Cloyes in other engines without issues.
WEDGE
Kimberley BC Canada
I'm curious about the cast iron tensioners. I've got a 2010 5.4 3V and will be doing the timing job in the spring. Those tensioners don't have a gasket? They fit the 3V engine with no problems? Thanks!
max78
AZ
You are correct, they do not have a gasket, I did put a little permatex gasket maker (dead old mechanics) on there as a just in case. They fit my 2009 just fine.
WEDGE
Kimberley BC Canada
excellent, thank you. I'll be using those when I do my timing job
