New Project Expedition riddled with problems. Build Thread.
Flexpedition
midwest
I replaced the same heater hose about a year or so ago and don't recall it being expensive.
My Duplicolor experience has been about the same - I have a couple white Fords. They should be honest and change their name to "We Duped You, Its Just Close To The Same Color". As long as it looks better than before & you are happy, so be it.
bt93
bt93
Corning, AR
i haven't had it out in the sun yet, it looks really close in the shop though. i had a bad experience using dupliclolr clear on my last oxford white (YZ) hatch paint job with it adding a yellow hue thats why i switched to a little bit better product.
1955moose
Did he say 30x40 ft shop, yikes! All I got is a carport. Are those side lights for baking paint? With all that room, I sure wouldn't have used spray cans, I'd have a 8 plus horsepower compressor and use my spray guns. His garage is perfect for a temporary spray booth. I'm jealous.
Will Williams
South Boston VA
The only reason i bought it is because the 3v engine is super quiet. almost oddly quiet, makes me nervous now that i think about it.
Now this is a GARAGE....
Love the space
Gregg Eshelman
Idaho
If you want the grille chrome again, get a can of Spaz Stix Ultimate Mirror Chrome and a can of their clear coat that's made for use with the chrome. If what you spray the paint on is is glass smooth the paint will shine just like a mirror. It can be used to make a sheet of glass (or glass smooth plastic) into a mirror.
To get paint super shiny, wet sand up to 2500 grit, then use a 3000 grit sanding pad. Then get a set of Micro Mesh pads. Lots of work but far cheaper than getting a big metal part chromed. Dunno what it'd cost to have a plastic grille redone with vacuum deposited aluminum like it was originally done.
Newark, DE
You mentioned an overnight electric drain in your list. Something to check is the back window wiper. My shaft was frozen and apparently I kept flipping the switch for it. That motor just kept draining the battery daily. Worth a look.
Good advice there, even if you don’t touch the switch it’s always trying to return to the resting home position
Newark, DE
Mine wasn't even the motor. The shaft mechanism going through the back window stiffened up in the bearing to the point where the motor couldn't turn it. Take it apart and grease or just spray lube and work it back and forth by hand until it moves freely.
Same with mine, replaced the wiper transmission.
Adieu
SoCal
I bought it about 10 years ago and its the best thing I've ever done. I'd never take my money back. its a 30x40 wood framed shop with 3 bay doors.
Awesome
How much did that cost you?
bt93
bt93
Corning, AR
Rear hatch stripped to bare metal and repainted! I also tinted the taillights and shaved the badges.
