Bad tail light housing
Does the owners manual of your 2007 also state that condensation is normal?
No it doesn’t, I get ford put it in the manual, but sometimes the owners manuals say wacky things. My owners manual says it’s normal for the motor to make pinging and knocking noises on some blends of 87 octane gas........I don’t consider such a thing “normal” or good for the engine as the manual states.
As for those with water accumulation in the bottom, the manual doesn’t say that’s normal.
drjeff
arizona
When my Expedition was delivered, one of the tail light lenses had to be replaced. It had more water in it than what was acceptable. Of course it had to be ordered and took several weeks.
Habbibie
Is it Christmas yet?
Chicago
The way I see it is it's a first year production of a complete redesign, all the complaints (including other threads on here) are to be expected, honestly if you didn't expect this many little issues then you're obviously not a gear head, none the less it's a nice truck and a lot of tahoe/suburban/yukon crowd are switching over to expeditions now and it's not so much Ford's little problems effecting people it's a 1st year of a redesign and this is to be expected. I'm sure the 2020 model year expedition would have worked out 90% of the complaints by then and they do watch the forums so what happens here... ford hears it and listens to it and being the multi billion dollar corporation they are I'm sure they will attempt their best to make the corrections needed.
Habbibie
Chicago
I’ve put 11k on my platinum over the past 7+ months, and I have no complaints other than harsh shifting between 3/4/5 when the engine is still cold.
Really? I get hard shifting between any gear on every vehicle I've DRIVEN when they're still "cold" even with what was considered brand new with anywhere from 1-5000 miles
Blackscreen67
Blackscreen67
Born to spool
TEXAS
I think my issues are more along the what if factors with things I find, and the rest are subtle annoyances like the lights.
The shifting will eventually be addressed with a revised TCM file ford sends out. They did it for the 2017 and 2018 f150s so I'm sure they'll roll it to the the expeditions when time comes.
The shifts he describes are a mix of shift hesitation blended with a gear slam.
In sport mode 3/4/5 shifts like a really bad gear hunt with the clutches locking and unlocking repeatedly.
lxrick
Germany
Most of all lights have an open vented design to get rid of moisture, even headlights. For decades..
The problem occurs and gets now even worse because of the use of LED lights which are much colder than the old fashioned bulbs.
In the past the heat of the bulbs kept the moist away or dryed the lights quickly. This has changed and is a prob now.
Another issue are colder headlights with HID or even more with LED´s in winter. This is where "premium" car makers have extra heated headlights.
To prevent moisture and blind headlights full of snow that doesn't melt anymore while driving.
Blackscreen67
Blackscreen67
Born to spool
TEXAS
Dealer said this is a very common problem that results in many warrantied F150 lights. Not as common on Expeditions, but mainly due to being less in service.
Uturn
It looks like the main issue may occur during pressure washing. With the shape of the body under the taillights I could see where if when pressure washing the spray is aimed toward the rear at the front of the taillights the spray could blow through the bulb seals(which do not appear that tight) into the lenses. I looked everywhere for the vents, including blowing compressed air in to the lights, and could not find the vents unless they are built into the bulb sockets themselves.
Sgt Darkness
East Tennessee
Noticed on my 18 one of the tail lights has moisture right in the same place. Will monitor to see if it get worse....
Atticus Mabrry
Greenville, SC
This is the worst! Even the passengers notice it. To the point I try and run the car for a while before I transport people when its cold. Hope this gets fixed SOON!
michguy
michigan
Since I am interested in replacing my 08 Expedition, I decided to look over the Expeditions at the local dealer to see if any exhibited the condensation issue. I only saw tail light condensation on one vehicle, a Limited model. I noticed that the tail light housing on the XLT models is somewhat different than the Limiteds which have LED lights.The cover on the Limited models even has a specific Ford part number whereas the XLT's have what looks to be essentially the same as on F150's. Anyway, I was convinced that perhaps this wouldn't be an issue on an XLT. HOWEVER, from reviewing the postings it appears that UTURN, who reported a literal flood in his light housing, described his vehicle as being an XLT. So much for me theory. So is this problem in fact not related to the LED set up? Is there a missing rubber gasket or some such that Ford eliminated to save 50 cents? I have been driving Expeditions (3) since 98 and never had this problem. I have had the "peeling paint on tailgate" issue that Ford refuses to accept responsibility for, and am somewhat nervous about the new model given Fords current cost cutting drive. Anyway, is it correct to say that this taillamp issue appears to be unrelated to whether or not the taillights are LED and XLT vs. Limited etc.?
As a side observation, from what I see and hear in my area, (southeast Michigan where there are a lot of A plan folks, which usually drives some demand for new vehicles), the new Expeditions are not exactly flying off the shelf, probably due to the pricing of the new model.
