Distance Indication Feature
philggg
illinois
My pre collision alert went off today. I was driving on a two lane road when the car ahead of me suddenly stopped to turn into a driveway. There is a bright red bar that lights up (like a heads up display) across the windshield in front of you. You can't miss it. I think it is a good feature.
dlcorbett
Air Force
tx
Hopefully one of us owners will figure out the distance indicator. I do like the fact that the collision alert is just that, pre collision alert. Some systems are too fwd with it and it becomes worrisome when it goes off on every vehicle in front of you.
MostlyHarmless
Sorry to rake up an old thread - but did this ever get solved?
I just bought a 2018 Limited Max with 302a. The adaptive cruise works great, and the pre-collision seems to warn me when it would be waaayyy too late to avoid an accident.
I (like others on this thread) seem to be missing the distance warning in my display showing me distances to cars in front and preparing the car for an accident
If all we have is the pre-collision warning that comes on when I am about to hit anything that is just rubbing salt in the wounds - telling me I'm already going to crash is not helpful :) And I've seen it work really well in other vehicles, so wondering if I am missing something here
Thanks
Mark
dlcorbett
Air Force
tx
Looking at the page again, mines does that, just not colored. I use the adaptive so that may be why i dont see the colors, ill try today
aggiegrad05
North Texas
Thanks
Mark
As far as I know, there is nothing that will warn you other than the flashing red light on the dash at the base of the windshield and the alert in the gauge cluster. It certainly seems like it is warning you too late, but I have had mine come on at varying distances depending on my speed, and it absolutely has saved my ass at least once; it slams on all four brakes and stops in an incredibly short amount of time...far shorter than I would think possible.
So I don't think you're missing anything, but don't let the pre- collision warning fool you, I think it knows what it's doing.
MostlyHarmless
Appreciate the feedback. Glad it is probably working OK
The user manual paints a slightly different story suggesting you get a colored image of a car showing the relative distance/risk to the car in front. I get a car image when using adaptive cruise but not when I am not using cruise. The manual suggests I should see something.
Also used to the GM system where a car symbol show between the white line graphic on the display to indicate that the car is actively monitoring the car in front - gives a great visual clue that the system is working and has identified a "target"
Thanks
Mark
aggiegrad05
North Texas
Thanks
Mark
The Ford adaptive cruise is similar to the GM in that regard; you will only get that grey/white image of a car when it "sees" a car in front of you...if there is open road in front of you, there will be no car image.
aggiegrad05
North Texas
Post #10 in this thread gets it right...according to the manual, the "distance alert" feature (the one that supposedly displays the colors) can be turned on and off. I will look for it next time I'm in the vehicle. It also says that particular feature is disabled when adaptive cruise control is activated.
aggiegrad05
North Texas
As I suspected, the available menu options don’t reflect what the manual says they should. Unfortunately.
Note: not a dadgum thing about distance indication
Blackscreen67
Born to spool
TEXAS
Someone needs to walk me through it, then, because the distance arrows do nothing unless I'm using the ACC. I have still never seen the red/yellow/green distance indicator.
Also, I had my daughter (bless her heart!) walk in front of the truck while I was in drive and behind it while I was in reverse. I got zero warnings; only saw her in the camera.
It seems to work fine when I'm parking, but darn it, I am more paranoid of hitting a child than a light post.
This is a pretty good reas9n to stay aware of your surroundings and NOT the technology. For anyone, not just you.
Tech causes more problems than solutions since people become lazy and rely on it.
MostlyHarmless
I tried an experiment last night and had the Collision detection set to highest sensitivity. Then I strung a tarp across my driveway and drove at it.
So the net is that that the system did work. The thing I didn't like is that the warning kicked in way after I would naturally like to to be breaking and honestly much later than I think it should be activating.
Perfect conditions, perfect surface at 20mph and it only just stopped the car. I have zero confidence that it would stop me in time in wet or slippery conditions. It just doesn't seem to be as good as other manufacturers similar systems in giving you plenty of warning.
Having said that, it is better than nothing, and to Blackscreen67s point above we should never allow ourselves to drive on tech rather than our own ability. It is, however, the only thing so far on the Expedition that I don't think has been engineered as well as it could be
Mark
dlcorbett
Air Force
tx
I believe its delayed because ford got dinged for over sensitivity for these features when first introduced in other models. I agree, for a 6k lb elephant, it needs to be a tad more sensitive.
Garrett
Kansas City
On the flip side, my wife’s keep brakes for me all the effing time even in low sensitivity. I may have pooped my pants once.
I have not experienced it in the ford yet. It brakes for you right?
Did anyone figure out the colors? Maybe they only light up when going over a certain speed?
aggiegrad05
North Texas
The colors have never ever come on for me in any circumstance. Nor is the setting even available on the menu.
I’m wondering if maybe it’s only available if you DON’T have the driver assistance package. For instance, perhaps if you have that package and the automatic braking that comes with it, you don’t get the colors...and vice versa. You know, one replaces the other.
It’s just very strange that it’s not even an option on my platinum even though the manual clearly says it should be.
Rotorhead451
Lowell, OR
In my experience, I don't think the automatic braking is anything close to maximum. When it activated, I awoke from my dreamy cruising and promptly applied my anti-lock brakes manually forthwith. I appreciate this feature . . .
Kmdcolo
I have a 2018 Platinum F150 and a 2018 Platinum Expedition Max. I can tell you that there is some difference between the dash displays. My F150 will indicate that there is a vehicle in front of me even when not using adaptive cruise. The car in front of me will be highlighted yellow or red depending on my distance and the speed I am traveling + distance. Some of the 8" display menus are different too. My F150 doesn't show the actual temperature of the transmission, only the gauge. I have tweaked this using Forscan. I'll post some pictures tomorrow.
Garrett
Kansas City
Tried with my platinum Expy today. No success getting the colors to display. The only time it has ever lit us is when I’m about to run over something at a considerable speed.
