Well, I'm now official...
scythefwd
2010 expy el limited
air suspension converted to coil.. still has notification
nav
rear overhead entertainment system
8 seat
mororized running boards
hd tow (or at least the 4 pin and 7 pin)
110k miles.
cooled seats
How do i disable the warning? Seen some threads abut cutting a wire but i think thats gen 1 only. Still figuring out the carseats.. The radio, the ac controls...
S
scythefwd
gixer2000 - is that done in the standard license or the extended one? Which screen is that residing in? I dont have a windows system I can use out at the car.. so I'm hoping I can do this on my mac..
gixer2000
Retrofit or Bust
Massachusetts
Its In the instrument cluster settings and need to have the extended license.
Unfortunately I believe it only works with PC or windows tablet.
Zero Offset
nav
8 seat
110k miles.
cooled seats
Did you buy a kit to do the air-strut to coil conversion?
S
scythefwd
Yeah, it doesn't even seem to be available via forscan lite on my android device. I ended up reloading my laptop with win 10 home and dual boot to elementary os (its a Linux distribution).. I got forscan to launch, but it couldn't connect to my Bluetooth reader running it in wine.. so the reload works. I'll mess with it later today, thanks again man.. much appreciated. Got my trial extended license installed this morning...
S
scythefwd
Gixxer, worked perfectly.. much thanks. Is there a spreadsheet somewhere or a decoding of the hex showing what number in each column indicates? It'd be a huge document to compile.. but would be immeasureably useful
Moderator
There is a FORSCAN Area on this Forum. Head over there, and you will find more info. The Most detailed sheet exists for the 15-17 Trucks, but some of those settings work on the Pre 15.
Moderator
The mobile app versions of FORSCAN can do zero programming. They are only for monitoring.
Only Windows as you discovered. Wine on Linux or MacOS will not work because of how the adapters are accessed. This is intentional. You don’t want any additional layers between you and the Truck while programming...That is asking for trouble.
gixer2000
Retrofit or Bust
Massachusetts
A couple people have tried to compile a list for the 07-14 but it always seems to drop off. As stated above try looking at the newer gen stuff and some f150 stuff. Usually they cross over
S
scythefwd
Yeah, 71 pages of posts is about the worst possible way to look through lol..
I think deweysmith was compiling info for that and then he fell off the face of the earth. Hasn’t logged in like 6 or 7 months now.
Moderator
Just look at the most recent pages, and find the link to the spreadsheet. Then you have what you need. Looking for a specific answer, do a search in the thread.
Plus, Sometimes correct answers require a little work. Reading is a piece of cake compared to the trial and error A Lot of us have done to bring what is known.
S
scythefwd
Loki, I'll search out the spreadsheet.. I'm looking to know what can be done.. not for a specific answer.
Does the spreadsheet also state what model year it worked on?
Moderator
It does. There are 2 tabs. One for the 15-17, and one for the 18+. Might not be a bad idea to add a tab for the earlier years, but the sheet isn’t mine.
