Looks like Bilstein is now making 5100s for the 15-19s!!
Black
Kentucky
18-19s
Front Part# 24-285056
Provides 0-1.6” of lift
Rear Part# 24-285063
Provides 0-1.5” of lift
Part numbers are the same for 15-17s
But only provide 0-1” of lift for the front.
I am guessing one will still have to run a spacer if you want to run 33”+ tires.
Not sure how well that would work on 5100s as they generally have a longer shock body than OEM shocks.
16plati
VA
18-19s
Correct on the spacer for 33s+.... for the front. Rear should be fine. I know the Readylift front spacer allows 33/12.50/20 on OEM +44 offset no rubbing
Dr0idattack
Bentonville, AR
I’m going to get 4600’s installed on Thursday. I’m interested in how the ride and towing characteristics will change.
Are the 5100s just for lifting?
Black
Black
Kentucky
5100s and 4600s when for the same model are valved the same. The 5100s body is slightly longer and has the adjustable snap ring to accommodate the lift.
Being that for EB Expeditions one was using the fronts from an F150 and the Rears from the older Expedition the valving for the 5100s and 4600s is likely different and the 5100s are going to be more fine tuned.
5100s have a setting for stock ride height.
If I was not going to lift it or was happy with only 1” lift I would use the 5100s listed in this thread.
If I wanted more lift I would not.
Not a good idea to use a spacer with the 5100.
I have the 5100s from the F150 giving 2” lift up front and 4600s from the older Expeditions paired with a Readylift 2” spacer in the rear.
I am very happy with the ride. I much prefer it to the stock ride and handling.
I have not towed with it yet but I did have about 1500 or so pounds of mulch and dirt in the back the other day and would have no idea it was back there. No sag nor did the ride change at all.
Black
Black
Kentucky
I can’t speak specifically for the ones listed as I don’t have them but I can only imagine they are.
My 5100s and 4600s are much more firm (a good thing in my book) the braking is also substantially improved as there is pretty much zero nose dive when you hit the brakes giving a much quicker and solid brake response.
Iamsam1117
Even the KYB is more firm also, I'd recommend either Blistein or KYB if upgrading your shocks and putting on a 3/2 lift kit.
Penumbra
Everywhere, USA
18-19s
You can view my posts for pics and more information of my offset but Ilm running these on stock suspension w/o issues and I tow.
285/60/20 ...it's posted...which is a 33.46" diameter and 3/8" wider than stock
16plati
VA
Are you saying you’re running a 285/60/20 on stock suspension? And I can’t seem to find what offset you’re running.
16plati
VA
Nvm. 20x9 +25s. Found it
Penumbra
Everywhere, USA
29814B69-EA56-4A77-909B-DA9AF020623B.jpeg And highly recommend brake upgrade minimum rotors and HD pads as the oversized tires affect the braking considerably. I have Ford recommended Stoptech cryos and use Hawk reds up front and yellows in rear. Night and day braking performance less upgrading to a 4 or 6 piston with a larger rotor which is big bucks.
Penumbra
Everywhere, USA
I have run my tires at max pressure for over 30 years. Don’t listen to the kids at Discount tire regurgitating information from a training handbook. I have circled the US in many types of vehicles in every weather condition and my job sites are often war zones and mud holes for topography. Never been stuck, my vehicles handle with precise response and my tread always wears even. I always get the 80psi???are you sure??? As an engineer major products are under engineered and the given spec on a product is given with max tolerances in mind for regular use unless noted otherwise. Your vehicle handles as it should at max psi for the given tire. Running an under inflated tire is dangerous at high speeds not allowing quick crisp maneuvering...there is roll in the tire and this is not only unsafe at high speed curves on mountains but actually will damage your tire and cause uneven wear.
