You can accomplish the exact same overall diameter and aggressive tires with 20” and 22” wheels. Looks way better in my opinion. To each his own.Wel looks like he actually uses his for off-roading not cruising the soccer fields ed
you cant beat the price though you could get a set like his raptors for 900 buck with brand new tires on them and sometimes the tps. 20 inch rims are ok but if you are trying to take it offroad the raptors are the best option in my opinion..but I lean toward a stockish look as opposed to ROCKSTAR type rims... that's just meYou can accomplish the exact same overall diameter and aggressive tires with 20” and 22” wheels. Looks way better in my opinion. To each his own.
Agree this isn't going to be everyone's cup of tea. Just happens to be mine.You can accomplish the exact same overall diameter and aggressive tires with 20” and 22” wheels. Looks way better in my opinion. To each his own.
Exactly! It would have cost me more than double what I have into this setup to put new wheels/tires on. These also came with TPS sensors installed.you cant beat the price though you could get a set like his raptors for 900 buck with brand new tires on them and sometimes the tps. 20 inch rims are ok but if you are trying to take it offroad the raptors are the best option in my opinion..but I lean toward a stockish look as opposed to ROCKSTAR type rims... that's just me
can you tell me more about offset I saw a guy who has 20 inch fuels with only 1mm offset.. his wheels look good too and I was going to do that until I saw this post... then I see that about the stock offset and was wondering ….thnkx for the post....Agree this isn't going to be everyone's cup of tea. Just happens to be mine.
You can get a similar look with 20-22" wheels, but you compromise some ability to air down for improved off road traction. The larger sidewalls also offer greater protection of the wheels. Both of these are important to me.
Like you, I also prefer the OEM look of these wheels. There aren't many aftermarket wheels that appeal to me. Especially when looking for +30 to +44 offset.
The lower the offset, the more the wheel will stick out towards, or from, the fender. Offset is the measurement of the hub in relation to the centerline of the wheel's width. So at +1 the hub is just 1mm to the right of centerline. This will give the wheel a more concave appearance or a large lip and the wheel will stick out of the fender more. Offset can also be negative, meaning the hub is actually to the left of centerline.can you tell me more about offset I saw a guy who has 20 inch fuels with only 1mm offset.. his wheels look good too and I was going to do that until I saw this post... then I see that about the stock offset and was wondering ….thnkx for the post....
Yes, forgot to mention that in the OP. As expected, the rear center caps won't clear the axel shafts. I'm not sure which approach I'll take yet. Leaning towards modifying the center caps.
those would be sweet.....As another posted. If you are actually going to be using your truck Offroad 22s are a horrible idea and 20s aren’t a great idea. From a capability standpoint let alone a cost standpoint.
I am a fan of more sidewall myself and not a very wide tire either, just flush or slightly onset of the fender. I want to keep stone slinging contained to the fenderwell.
17s or 18s with 33-34s are about perfect on these rigs. I was close to pulling the trigger on a set of the 1st Gen Raptor wheels. But I did not feel like fooling with the center cap or rear axle shaft.
I just with the OEM XLT 18s and actually liked them far more than I expected. So I’ll just put that money towards other actual useful things, like sliders and a winch.
Now if I could find a set of Raptor Beadlocks for a decent price I’d be grinding the axle shafts in a heartbeat.
I'm casually keeping an eye out for a similarly sized spare. I haven't actually checked to see if a 34" spare will fit in the factory location. Stock spare will do in a pinch for now.Any plans to accommodate a similarly sized spare tire? I assume the stock spare could be used temporarily on the front when in 2WD to avoid any driveline issues with different sized tires.
I'd also be interested in sliders. If you come across anything let me know!As another posted. If you are actually going to be using your truck Offroad 22s are a horrible idea and 20s aren’t a great idea. From a capability standpoint let alone a cost standpoint.
I scored a set locally....my build is finally setting sail....As another posted. If you are actually going to be using your truck Offroad 22s are a horrible idea and 20s aren’t a great idea. From a capability standpoint let alone a cost standpoint.
Very nice!View attachment 30047
Lifted 2018 Ford Expedition by Matt Krepp, on FlickrYeah looks sick bro! Good luck with the articulation stuff. I know at full drop your UCAs are going to be sitting on the springs. I can tell you that much. Not sure about fully compressedHere she is with the ReadyLIFT 3/2 installed. Tires still rub, but just the fender liners at full lock. Still need to test articulation to make sure they clear the fenders at full stuff. If it's just the fender liners, I'm not too worried about the rubbing.
look nice bro... can you show off more pics like.. I like this offset and with the lift it looks amazing and still stock... love it bro.. I still cant decide if I want to go get the svt rims. I have the guy holding them for me till Friday... I think I will after seeing this....Here she is with the ReadyLIFT 3/2 installed. Tires still rub, but just the fender liners at full lock. Still need to test articulation to make sure they clear the fenders at full stuff. If it's just the fender liners, I'm not too worried about the rubbing.
Thanks! And, yes, I noticed the UCAs are very close to the springs at full droop. This is not the ideal lift for off road, but it'll get me by for now until something better (hopefully) comes along. Until then, I have my Land Cruiser for the gnarlier stuff.Yeah looks sick bro! Good luck with the articulation stuff. I know at full drop your UCAs are going to be sitting on the springs. I can tell you that much. Not sure about fully compressed
Thanks! Yes, I can get a few more pics, but it might be a couple days.look nice bro... can you show off more pics like.. I like this offset and with the lift it looks amazing and still stock... love it bro.. I still cant decide if I want to go get the svt rims. I have the guy holding them for me till Friday... I think I will after seeing this....
expy by Matt Krepp, on FlickrThey appear to be a bit forward of center. I can't say I recall specifically, but I'd venture to guess the rear wheels aren't centered in the wheel wells in stock form, either. The effect is a bit more exaggerated in my case.Is it just me, or are the rear tires not centered in their wheel wells?
The spacers change the angle of suspension and will pull the wheels forward. Happened on mine too, nothing you can do about it except go back to stockIs it just me, or are the rear tires not centered in their wheel wells?
