Is Moog the only option for stabilizer bar bushings?
Password
Unless I somehow bought the wrong ones, the set I bought in 7/2017 are already making noise.
Edit: front bushings
Adieu
SoCal
There's a number of different sizes. Yes, even within same model year.
Password
Password
Would over tightening the mounting bolts cause an early demise? I'm thinking that is what happened. Anyway, bought some AC Delco ones this time.
Password
Password
Did you try spraying a shot of silicone spray on them ?
No......lol. I'll give it a shot before I change them.Should I loosen the brackets and spray, or just douse what I can?
Black
Kentucky
I use Ballistol on my suspension parts and rubber boots. It will creep in.
It is a great penetrating lubricant and corrosion prevention.
Only downfall I have found is it smells like a combination of feet and licorice.
Silicone will creep a bit but some can be a little thicker and not creep as well.
Give Ballistol a try. It is safe on pretty much everything so you can spray pretty much everything down and not have to worry.
I do my best to keep it off the faces of the rotors.
1955moose
Feet and licorice! Man does that paint a picture for your nose.
Password
Password
Does a bad front wheel hubs sound similar to bad stabilizer bar bushings/end links?
