juan214
So I started to address this A/C issue last year figured I would continue with it this year.
Curently A/C blows at vent a constant 78 degrees. Some what cool depending on the day. Went to check the level this past week end to see if the system emptied out again. When I took the cap off there was some UV dye at valve and some pressure releive, figured that it was no big deal. I know someone will say use a manifold set to check it. I just wanted to do a quick check to see if it leak out as it has for years. Anyway it didn't leak out so the work I did last summer went well. It was 85 degrees out so I should be at 55/379 at most. System was overcharged so I had some purged out now its at max 55/379 and still blows 78 degress.
99 Expy EB w/ rear a/c & heat
Last Year it was empty blowing 100 at the vent.
Result: Last year got it down to 58 - 60 degrees at the vent this year it's at 78 degress at vent.
Any sugestions are welcomed.
Thanks In advance guys
- Got a loaner Vacuum Pump
- Got a loaner Gauge set
- Replaced compressor and clutch (new) w/ .8 oz. oil
- Replaced all the o-rings but two they were up above an exhaust shield
- Replaced PAG oil 3 oz.
- Replaced Expansion Valve
- Replaced Orifice Tube
- Replaced Receiver Drier / Accumulator
- Replaced HP Sensor w/ O-ring
- Replaced R-134A from Walmart
