I'll look at the plenum layout after work and answer your question.
Also in reply #11 you stated no condensate or dripping but recently said it stopped. Can't have both.
l looked at the plenum from under the dash. Looks like the EVAP sits in the lower half of the plenum. Condesation builds up drips downwards and to the left (to drivers side) then down again to the firewall and out. It sits in it about an inch it would have to fill up to that point to get to the filter and overflow into cabin.
What a PIA to check this out. Took inner fender off just to see from wheelwell. Crawled under to veiw up. The drain looks clear or is it a vent I see from underneath?. Is there a picture showing that there is both a vent and drain?
There was no dripping anywhere. IR Reader says the top of the dryer ranging between 90 - 100 degrees. The line next to battery is cool nothing major to the touch and was 85 degrees with very little condesation. My dyrer has a foam jacket with a hole at the bottom.
Before dropping the 20 pounds of pressure:
Temps
Low Line: 85 (very slight condensation but visible)
Dryer: 90 - 100 up and down
After dropping the 20 pounds of pressure:
Temps
Low Line: 125
Dryer: 135
New Question (probably dumb)
Since the system was releived of 20 pounds of pressure any idea of what that may equate into in ounces of refrigerant?
