I had talked to some dealers earlier in the year. None of them had done that, I had one that would order the part and try to put it on. The other one just straight up said they wouldn't do it. And I got a quote about 4000 with all four light assemblies with harnesses.I end up just changing the bulb of the tail light for now and I got the LED for the front turn indicator, but I don't have a very clear instruction yet so I'm not sure do I want to just try to go behind the front wheel well cover. I'm also looking on ebay for used tail lamps they usually goes around 500. They appeared to have the same plug, but don't know if it would work or not.The 2018 Ford Expedition Platinum comes with LED Front/head AND rear/tail lights .. however, my 2018 XLT FX4 didn't .. I am also curious if it is just a bulb replacement OR the LED light fixture is different .. anyone know the details as to what it would take to get the same LED light setup as the Platinum? Is it as simple as getting a different bulb? OR do you need to purchase a new lens enclosure? I would not think there is any changes or adjustments to fuses or wires? anyone have an idea???..
Has anyone found a better performing bulb change out to the stock headlights?
Are the stock halogens in a projector housing? Or is it a reflector? Please do not refit HID conversion into a non-projector housing. This just makes a crap ton of glare for on coming vehicles. I see it all the time. Personally, I wouldn't even use LED bulbs in the main headlight or fog light housings either since it will not cast enough light. This is the reason, IMO, that you see OEM LED setups as multi lamp housings. One LED bulb in a headlamp housing won't cast enough light.
Also agree. Personally, if I had a halogen setup (I have a platinum with LED's all around) I would swap my fogs for PIAA Ion Crystal bulbs (they produce yellow light, but shine to oncoming as more white) and PIAA bulbs in my headlamps. I have been 100% satisfied with their performance and durability.I totally agreed with you, I would only run led in Fog light to color match with main low beam. Expected to decrease light output due to the way the LED is designed can't put out a 360 degree light pattern a halogen bulb or HID would. But putting HID in small fog light housing is just asking for trouble.
On the older Explorers, yes. I have the same setup with my Lincoln MKT. HID's in projector housings that use a shutter to toggle between lo and high beams. The newer Exploders have LED headlamps in reflector housings that are also used as DRL's.The stock low beam halogens are in a projector housing, while the high beams are reflectors. The stock Philips halogens are terrible. The Silverstars are a big improvement and contrary to some beliefs, the quality LED's perform very well in the Expeditions projector housing. My understanding is that members running HID's are also very satisfied with them. As bad as they are, the Expedition headlights are better than the stock Explorer headlights that use a single projector with a 9005 bulb with a shutter that changes the beam pattern when selecting high beam.
If the switch is on headlights the system should shut of after ten minutes, however it will not shut off if the switch is on parking lights.Does anyone have an issue with the light switch in any position other than automatic? When exit the vehicle and lock, the light will remains on until your battery drain? Why is this still in 2019 these days?
It stays on for a little while then it turns off eventually. I believe it's about 10 mins?Does anyone have an issue with the light switch in any position other than automatic? When exit the vehicle and lock, the light will remains on until your battery drain? Why is this still in 2019 these days?
Front turn signal is a 7443 bulb, you may need to cut trace which wire is the signal and cut it and put a resister in between to prevent hyper flash if you install LED. You can gain access to it from the hood, but you need a helper with small hand.By the way. Does anyone had some luck with changing the front turn signals? I tried from the access flap in the wheel well and the cover from the engine bay and they were both too hard to reach.
Thanks, I tried to remove the plastic cover piece on the very front that's directly above the headlight assembly. I saw that gap and then I knew I weren't able to do that. I got Lumen's can-bus compatible ones for both front and back. After switching to the led for the back it worked fine without a resistor on the outside, but it's hyper flashing on the dash.Front turn signal is a 7443 bulb, you may need to cut trace which wire is the signal and cut it and put a resister in between to prevent hyper flash if you install LED. You can gain access to it from the hood, but you need a helper with small hand.
But! looking at the wire, looks like it only two small wire. I believe that the bulb is feeding low voltage as DRL light and blink at 12-14v when you use your signal. So If you going to use LED the DRL will not be sufficient to turn the LED on, may only works when you trigger signal. In my case I did try install a pair of VLEDS 7444 and it didn't stay lid as DRL but doesn't blink.
Thanks, finally put that in after removing the whole plastic cover piece. The Lumen ones I got can output two brightness settings. It can stay lit with low beam and also flash as the turn signal.I made a correction: In my case I did try install a pair of VLEDS 7444 and it did stay lid as DRL but doesn't blink.
