2018 Expedition LED headlight conversion
taaangy234
US
Lukewang01
Upstate NY
The 2018 Ford Expedition Platinum comes with LED Front/head AND rear/tail lights .. however, my 2018 XLT FX4 didn't .. I am also curious if it is just a bulb replacement OR the LED light fixture is different .. anyone know the details as to what it would take to get the same LED light setup as the Platinum? Is it as simple as getting a different bulb? OR do you need to purchase a new lens enclosure? I would not think there is any changes or adjustments to fuses or wires? anyone have an idea???..
I had talked to some dealers earlier in the year. None of them had done that, I had one that would order the part and try to put it on. The other one just straight up said they wouldn't do it. And I got a quote about 4000 with all four light assemblies with harnesses.I end up just changing the bulb of the tail light for now and I got the LED for the front turn indicator, but I don't have a very clear instruction yet so I'm not sure do I want to just try to go behind the front wheel well cover. I'm also looking on ebay for used tail lamps they usually goes around 500. They appeared to have the same plug, but don't know if it would work or not.
Uturn
Has anyone found a better performing bulb change out to the stock headlights?
Any of the high performance bulbs will be an improvement on the low beams(SilverStars, PIAA, etc). The high beams use a H11 bulb which I could not find in a high performance bulb. You can substitute a H8 high performance bulb, but they are only 55W compared to the H11's 65W. Also, LED lamps or an HID conversion seems to be the be the best solution to the stock non-LED headlights.
Gumby
Beaumont, Alberta
Are the stock halogens in a projector housing? Or is it a reflector? Please do not refit HID conversion into a non-projector housing. This just makes a crap ton of glare for on coming vehicles. I see it all the time. Personally, I wouldn't even use LED bulbs in the main headlight or fog light housings either since it will not cast enough light. This is the reason, IMO, that you see OEM LED setups as multi lamp housings. One LED bulb in a headlamp housing won't cast enough light.
taaangy234
US
I totally agreed with you, I would only run led in Fog light to color match with main low beam. Expected to decrease light output due to the way the LED is designed can't put out a 360 degree light pattern a halogen bulb or HID would. But putting HID in small fog light housing is just asking for trouble.
Gumby
Beaumont, Alberta
Also agree. Personally, if I had a halogen setup (I have a platinum with LED's all around) I would swap my fogs for PIAA Ion Crystal bulbs (they produce yellow light, but shine to oncoming as more white) and PIAA bulbs in my headlamps. I have been 100% satisfied with their performance and durability.
Uturn
The stock low beam halogens are in a projector housing, while the high beams are reflectors. The stock Philips halogens are terrible. The Silverstars are a big improvement and contrary to some beliefs, the quality LED's perform very well in the Expeditions projector housing. My understanding is that members running HID's are also very satisfied with them. As bad as they are, the Expedition headlights are better than the stock Explorer headlights that use a single projector with a 9005 bulb with a shutter that changes the beam pattern when selecting high beam.
taaangy234
US
Does anyone have an issue with the light switch in any position other than automatic? When exit the vehicle and lock, the light will remains on until your battery drain? Why is this still in 2019 these days?
Goff69
