I had talked to some dealers earlier in the year. None of them had done that, I had one that would order the part and try to put it on. The other one just straight up said they wouldn't do it. And I got a quote about 4000 with all four light assemblies with harnesses.I end up just changing the bulb of the tail light for now and I got the LED for the front turn indicator, but I don't have a very clear instruction yet so I'm not sure do I want to just try to go behind the front wheel well cover. I'm also looking on ebay for used tail lamps they usually goes around 500. They appeared to have the same plug, but don't know if it would work or not.The 2018 Ford Expedition Platinum comes with LED Front/head AND rear/tail lights .. however, my 2018 XLT FX4 didn't .. I am also curious if it is just a bulb replacement OR the LED light fixture is different .. anyone know the details as to what it would take to get the same LED light setup as the Platinum? Is it as simple as getting a different bulb? OR do you need to purchase a new lens enclosure? I would not think there is any changes or adjustments to fuses or wires? anyone have an idea???..
Has anyone found a better performing bulb change out to the stock headlights?
Are the stock halogens in a projector housing? Or is it a reflector? Please do not refit HID conversion into a non-projector housing. This just makes a crap ton of glare for on coming vehicles. I see it all the time. Personally, I wouldn't even use LED bulbs in the main headlight or fog light housings either since it will not cast enough light. This is the reason, IMO, that you see OEM LED setups as multi lamp housings. One LED bulb in a headlamp housing won't cast enough light.
Also agree. Personally, if I had a halogen setup (I have a platinum with LED's all around) I would swap my fogs for PIAA Ion Crystal bulbs (they produce yellow light, but shine to oncoming as more white) and PIAA bulbs in my headlamps. I have been 100% satisfied with their performance and durability.I totally agreed with you, I would only run led in Fog light to color match with main low beam. Expected to decrease light output due to the way the LED is designed can't put out a 360 degree light pattern a halogen bulb or HID would. But putting HID in small fog light housing is just asking for trouble.
