Front turn signal is a 7443 bulb, you may need to cut trace which wire is the signal and cut it and put a resister in between to prevent hyper flash if you install LED. You can gain access to it from the hood, but you need a helper with small hand.
But! looking at the wire, looks like it only two small wire. I believe that the bulb is feeding low voltage as DRL light and blink at 12-14v when you use your signal. So If you going to use LED the DRL will not be sufficient to turn the LED on, may only works when you trigger signal. In my case I did try install a pair of VLEDS 7444 and it didn't stay lid as DRL but doesn't blink.
