Dealer wouldn't rotate my tires!! Faulty lug nuts??
Jeff T
Chicagoland
I stopped at my local dealer today for their oil change/tire rotation combo. Service Writer came out and said they wouldn't rotate the tires. Reason - Apparently the lug nuts are a piece of chromed metal over a lug nut to give them the correct look. He stated the outer caps get loose and deform with ice and cold. He suggested I replace the lug nuts with something aftermarket that is solid.
He also said he hoped Ford would recall them because of this issue.
Truck is a 17 with 96k on spent. Early life I GA, one winter in Chicago.
Anyone else experienced this??
creef14
VA
The POS lug nuts yes, dealer refusal no.
The dealer offered to replace mine for the small sum of $200+, or $85 if I brought my own lug nuts. I passed and replaced them myself. Depending on how bad the originals are you may need to buy a turbo socket to get them off.
Adieu
SoCal
Are the capless "fat" steel mushroom lugnuts found on some F150's and Expy's with steelies safe?
StephanSloan
East Greenwich, RI
Yes, I have had corrosion inside the lug nut cause it to plump up and deform. I bought 10 lug nuts and just swap in new ones when neededt brake jobs or tire rotations.
I would not hold my breath on the recall...
Good Luck,
Stephan
mquick5
Buckeye Country
Yes, but my dealer replaced them all got FREE! But there most likely the same pos lug nutts that were on the truck.
Sent from my front porch using Tapatalk
ssmock
Kansas City, KS
I had the same issue on two of my wheel lug nuts. I use discount tire for all of my tire needs and rotate every 3K to 5K miles. They replaced them for $65. Chrome, all steel and looked a little different than the originals from Ford but looked nice. Cheap insurance if something happened on a trip and couldn't get a lug nut off. Well worth the $65.
Black
Kentucky
So will the dealer not do anything that involves removing the wheels?
Certainly would not take my vehicle there if they don’t trust themselves to remove a Ford factory part.
f150dave2002
Aptos, California
The deformation also occurs with the use of air impact tools when tire service occurs. I worked at ford and couldn’t get mine covered even though I had every service documented for 45,000 miles at the dealer. I went with dorman brand on amazon for a replacement and have been pretty happy with them.
Dorman 611-288 Dometop Capped M14-2.0 Wheel Nut, 21mm Hex, 54mm Length (Box of 10) https://www.amazon.com/dp/B0045IJF1I/ref=cm_sw_r_cp_api_i_4kxDDb2ZQ9W7R
Adieu
SoCal
Won't fit a 17, gen 3.5 uses different pitch (M14-1.5 iirc?)
2017 with almost 100k on the clock? Daaamn.
Uber / livery? Travelling salesman?
I bought a new 2015 Expedition Limited 4x4, and have always had the oil change service & tire rotation done at a Ford dealer.
At the beginning of this year, the service advisor told me that 20 of the 24 lug nuts were swollen and need replacing. Although I had purchased the Ford premium care extended warranty, the lug nuts were not covered.
Since I was having the tires rotated (The Works package), the dealer only charged me for the lug nuts. I was concerned that a wheel and tire could not be removed if I got a flat.
Ironically, several months later, scrap metal fell from a POS truck on the highway, striking the car in front of me and flattening one of my tires (it put a hole about the size of a quarter in the tread, and some of the metal belt was pulled out).
I had AAA install the spare, and the service guy said he often sees lug nuts swollen that he can not remove with his tools. He remarked my lug nuts looked new.
Ford clearly has designed a poor quality lug nut, which can cause problems with removal when they swell.
NASCAR Mike
Syracuse NY
Ford has been using the same crap lugnuts for many years now. I had the same issue on my 17 Expy, 2013 Mustang GT and my 08 Expy.
I replaced all of the with McGard lug nuts. They come with a lifetime warranty.
GaryB
Atlanta GA
I just replaced all of mine with Gorilla nuts from Amazon. They look much better, and I'll never be stuck on the side of the road with a lug wrench that doesn't fit.
pitdexion
Rochester NY
Going through this right now. I managed removing the chrome caps which reduces the size to 20 mm and they still would not come off with a 3/4" impact. So broke out the induction heater tool to get em hot and they just rounded off. Turbo sockets just made matters worse. Drilling or torching them are the last options now so do yourself a HUGE favor and replace these pieces of shit with solids. Pretty bad having to work on your truck to work on your truck! Good luck.
CaptOchs
Rochester NY
It's not just Ford. Many other car makes are doing it. I replaced all of them on my Charger. I had several that were spun. Basically you just need a large wood chisel and a hammer. Just beat away at it without damaging the studs or rim. Once you mutilate the cap, you can rip it off with pliers to get at the actual nut.
GaryB
Atlanta GA
ugh, sorry to hear that man. I had luck pounding a 22mm 6 point onto them, then a 1/2" impact...Obviously you're way past that now.
On another note, I used to live in the finger lakes and spent 3 years driving up to Lyell Ave in Rochester for work every day. Hope you're enjoying the nice weather :)
Adieu
SoCal
Is it just one?
Maybe epoxy/weld/braze/solder on a socket, THEN impact that bugger?
Or...possibly... don't impact it, go gentle? You figure that crap is actually wedged in there with some random 3digit number of ft-lbs by some impact-happy technician, or just gradually rounded off on account of being pieces of crap?
Btw a beefy bolt extractor might also do the trick
Adieu
SoCal
PS pleeeeease tell us you at least used DEEP turbo sockets?
