Build 19205 is now officially available through the Ford website and over-the-air. Happy updating!
Now you got my attentionThe answer for the version of Sync 3.x
3.0 is for 2018 and below (some 2019's)
3.3 and above is for 2019 and above (but not all)
If you are at 3.0, right now that is as far as it's going, unless Ford changes how that is setup...
If you are at 3.2 or 3.3, you will get newer updates as they come out
3.0 does not have enough storage, and is not setup for more than what it has (again unless Ford decides to change that)
3.2 and above has more room as well as better storage layout.
That is a simple way to put it... there are alternatives out there, but not for the novice. 8)
I tried to update my software to 19205 via WiFi yesterday. It tried to scan for updates for a couple of hours and never completed. Is this common?
I checked owner.ford.com and was able to update to build 19205 via USB. Still Sync 3.0I got mine last week a 9/19 build date and I still have the Sync 3.0 and 18093 build. Seems to be pretty random what you wind up with on 2019s.
Where can I find the upgrade to put on thumb drive? Can I get it on my phone and connect to the truck with a USB cable?It takes less than 10 mins with the USB
The file I downloaded was JR3T-14G381-AS.zipI got the "update" installed, but it still says my software version is 19149. The update has JR3T-14G381-AS shown as the updated software name. What is the name of the 19205 file?
