Key Programming
Langer
Chicago
Where have you guys been going to have your new key cut? I went to Ace and Home Depot this morning and they won’t do it.
rjdelp7
2000 XLT
NY
My local Valu home center, did 2 of my, PATS2 ebay blanks. The first time, a kid did it, no questions. The second time the lazy manager said, it wouldn't work. I explained, I had one done before. He found the slot on the machine and cut it. It took less than a minute.
D
dcsang
I just did this today for my 2012 focus, would be very safe to assume the 13 expedition is also compatible.
Thanks for the confirmation. I'll go this route if the need arises again. May I ask which OBDII device you used?
D
dcsang
Scanning software such as AutoEnginuity also programs keys.
I haven't heard of this but it looks interesting. The Enhanced Ford Expansion supports quite a bit and the combination appears to rival some of the diagnostic tools in the $1,000+ range.
Icemanjones
Orange County CA
Yeah I have an 07 and dealer wanted to charge $35 plus $160 for programming for a plain key. His service guy slipped me a card for a guy who does them. He had a programmer, tablet etc and 15 mins I was out for $80 total. I dont mind supporting local business if they do a good job and I tend to stay away from anything computer in nature if its not for work. Ive fried way too many hard drives in my life lol.
D
dcsang
creef14
VA
That appears to be the adapter of choice. I was also looking at the OBDLink MX+but still trying to determine if there's any significant difference in functionality for Ford vehicles.
that's what i use and it works great, never had an issue
Johnathan M
Klingerstown, PA
Wife and I bought for her an '17 Expy EL previous rental that only had one key. I bought two more on Ebay after reading feedback. I knew I want to enable the trailer brake controller so I bought the
OHP ELMconfig Forscan OBD2 Adapter with MS-Can & HS-Can Switch for Ford DIY Diagnostics on Windows
Sold by: OHP Tools for 30 bucks. I was reluctant to erase all keys so I just added one using ForScan and free extended license. Later I found I could add OEM remote start so I bought two OEM remote start keys
KeylessOption Keyless Entry Remote Control Fob Uncut Blank Ignition Car Key Remote Start for CWTWB1U793 (Pack of 2)
Sold by: KeylessOption $44.95 on Amazon.
I did have to delete all keys programmed and start over since there were now 4 keys. I followed the instructions in this forum and ForScan site. It took several tries for the remote start to programming correctly but it did work. But getting the car to start with the key was never an issue. I have also added driving lights to the Expy and programmed a friend's '18 F150 to remove the Auto Stop/Start feature.
My local Locksmith cut the new keys for me.
Here is a link to PATS programming on the ForScan.org site
https://forscan.org/forum/viewtopic.php?f=6&t=839
I know this is an old thread, but it's relevant to my situation. I have a 2013 Expedition. We purchased it used, and the keys (2) we were provided do not have the center button for remote start. However, the Expy does have remote start from Ford... it's just controlled by a separate fob. I would like to add a key like you pictured with the center button for remote start so I don't have to carry the separate fob around to do the remote start. Is that what you did, or did your original keys have the center button for remote start. If your original keys didn't have that center button, and the ones you bought do, how did you go about programming them? Is it the same process as programming a new key with ForScan, or did you have to do something different to get the remote start button to work? Did you have to erase all existing keys and start fresh, or were you able to just add those keys and the remote start automatically got programmed as well? Hope all my questions make sense! Thanks!
Trainmaster
Old School Member
Rockaway Beach, NY
I don't believe it would work. The remote start on the 2013's were made by Code Alarm for Ford. It's a separate unit from the car's locking system.
Trainmaster
Old School Member
Rockaway Beach, NY
Look under the dash by the steering column. The remote start is a black box hanging from or in the wire harness under the dash. If there's that box there, probably secured with tie-wraps, the remote start was installed.
