CM Saw Dust
Hey I have been searching all over the internet for fender flares for my 19, its going in on wed for the ready lift and new rims and tires any help would be greatly appreciated
where did you get those fender flares they look great!Tires are Toyo Open Country AT’s 12.5”x35”R 20’s. MPG combined (mostly in town) is around 14. Highway usually goes up to 17 or 18. Rides great! Tires are very quiet considering. Pick your wheels carefully (offset is important). Mine are +18mm. Truck is awesome off road.
He had those were custom made from a set of Raptor flares. I haven’t been able to find anything on the aftermarket.where did you get those fender flares they look great!
Very light trimming of the inner fender liner. I have the retractable running boards. I did shorten them about 3 inches. Simple to do.
Just finished mine a couple weeks ago. 33x12.50R22 Ridge Grapplers
Does anybody here have any legitimate concern about wheel spacers? What is the effect on the warranty w/ wheel spacers? I guess honestly the same question could be asked about the lift/leveling kits as well.
I definitely didn’t think there was anything to it until.....I had an issue. But I do love the look with factory wheels.
Technically, if I add tires that are 20mm wider than stock (305/45 R22), I can add a 10-15mm spacer and should have perfect clearance.
I say 10-15 because that 20mm width is split between the front and back half of the tire. The full 20mm addition is not to the back or the tire and rim.
10mm is a wee bit more than 3/8 inch. I think that will still give about an inch grab of the lug since Ford lug bolts are 1.5 inches (as per Custom Offset website).Wonder if a 10mm spacer is ok with factory lugs—?
Can you tell me more about the trimming of the running board. Does it just have a capped end that you remove and trim the
Still havent seen any FX4's on this level with stock wheels......other than the one on ready lifts site.
Do y'all think there is enough clearance with the stock FX4 wheels for a 285 75 r18 or would the 34" (285 70r18) be a better option?
