I have BlackVue DR-900s-2ch. Was concerned regarding the length of the rear camera cable, but it worked perfectly fine - like they designed it for Expedition MaxHere is mine setup. Main concern was high current for steering wheel heater and dash cam battery pack which charges at 9A and came with 20A fuse (20A + 20A). Because of the shape of fuse box I couldn't push the tap all the way down. Cannot say the connection was loose or flimsy, but just not full enough - which bothered me for some time. Finally I took the panels off and checked connections when both were at full power - temperature didn't go above 47C (ambient was ~17C). Considering I will use steering wheel heater mostly in winter - that should be good. Keep in mind that fuse tap orientation matters - fuses should be connected in parallel and not in series which could burn the bottom fuse in the fuse tap.
Excellent info on the dashcam install.
I am almost done but since I have dual cam (blackvue) i am bit confused on the rear camera mount. Since the rear lift gate extends up.
If anyone has a dual cam set up and can post some pics here it would be really helpful
What did you anchor the cable to the glass with, was that something supplied with the camera?
Adhesive cable clips came with dashcam. It’s been over a year since I installed it, so far so good.What did you anchor the cable to the glass with, was that something supplied with the camera?
This camera is on my short list... any complaints on it?
Thanks for the info!Adhesive cable clips came with dashcam. It’s been over a year since I installed it, so far so good.
No real complains on the camera, but I don’t use cloud features, so cannot really speak for that. Other than that does what it supposed to do, install and forgetI’m very happy about parking mode - records 5 seconds before triggered event by motion or/and G-sensor. Sensitivity of motion sensor is configurable. G-sensor is configurable for parking and normal modes separately.
I wish it had SD card encryption to protect privacy in case of somebody gets access to dashcam/card - but that’s not very common in the industry.
Thanks a lot@idesi1
There is a user on here that just recently posted some pics where they wired the rear camera through the existing harness conduit, it ended up looking pretty clean. The tricky part is the rear glass, since it opens you need to route the wire with the existing defrost cable to prevent a bunch of slack. I wish I could link that thread but I don’t remember where it was.
check the first page of this thread, there’s some pics on the fuse to tap.So, I ran all the cabling for the front dash cam. Came up with issues on running the rear cable.
I will be finalizing the front cam wiring tomorrow.
What fuses did everyone use? And are there any that should be avoided when the Auto Start Stop activates? I would hate for my camera to stop when ASS activates.
Thanks!
What issues did you run into running the rear cable? Trouble getting the interior covering off?So, I ran all the cabling for the front dash cam. Came up with issues on running the rear cable.
Out of curiosity, camera are you installing?Length was too short the route that I initially chose. Need to re-route along the roof line versus the floor.
Thanks. I’m in the market and I’ll check this one out.Viofo A129 Pro Duo
I was going to run my dash cam from that fuse but I’ll be damned if it will cause issue with my heated steering wheel, I’ll have none of that.So my local car audio shop hardwired my dashcam, radar detector, and USB Type C charger in my Expedition on switched fuse #37 (heated steering wheel). All of the hardwire units work great without any issues, however now my steering wheel is intermittent. Sometimes it works fine, sometimes it doesn't work at all, and sometimes it will work fine initially, then shut off.
Anybody either experienced this before or have any idea what might be causing this?
