I have said it too many times....a catch can will benefit any engine with a PCV system. Why put crankcase by products back into the intake system? Why dilute the fresh air and fuel charge in the cylinder with crap?
Right now, I'm filling the 3oz cup on my JLT weekly with the milky mix and some oil. I also smell oil outside and in the cabin. More noticeable after engine has warmed up, shut off, then started up again (like running to the store). I took a look under the hood and didn't see any oil residue around the valve covers. I'm at about 48,000miles in my '17. First vehicle I've had where I get this oil smell. Any advice you guys can give is much appreciated.
I get the same smell, sort of an oily/gas smell. Usually when I smell it I go check the catch can and it is full. Also weekly or so, depending on driving habits that week. Ours gets idled a lot, and short trips, I'm assuming that is why I have so much in the winter.
I just installed the JLT kit on my 'new' 50k mile '17 EB; hope it's not too late. With the gen1 - 3.5EB, there is no Ford approved method to clean intake valves. Cleaning these valves can push chunks of carbon and sludge directly into the turbine wheels. Any wheel imbalance created from this nastiness can result in very fast bearing wear and ultimate turbo failure. New Mahle turbos at Rockauto are running about $421 each. Installing 2 of these bad boys is likely twice the part cost or more. A catch can for the DI-ONLY engines is a no-brainer in my book.
I'm expecting to empty the catch can reservoir at 3k miles or so.
If you are emptying the can weekly, I would suspect oil level too high as previously mentioned or PCV valve is sticking open. Pull and clean it in gasoline or solvent, better yet, a new one is about 6 bucks. Good luck!
Nope, I change my own oil. It seemed high when I checked it before I changed it so I drained from the plug on level ground and measured how much came out. Them added 5 qts of amsoil, then checked next day and added another half qt to bring it right in the middle on the dipstick. I just checked it a week ago and it was still good. after seeing how much crap the can was catching, I was sure it would've dropped. Must not be that much oil and mostly moisture and other shtuff getting caught in the can.Did you have an oil change recently? Perhaps the oil level is too high.
I will check the pcv valve. Thank you for the advice.In the Cool it is completely normal to have to empty more often, especially if you are idling a lot to warm the Truck up. In Warmer weather it will clean up a bit and decrease in volume. No PCV sticking open.
Anybody know if installing a catch can will void warranty? My '16 has 53k miles and occasional stumble idle, so I'm strongly considering adding a catch can. I have full extended warranty through 100k miles, so I don't want to void or have claim issues in the future.
I don't think there is a PCV valve....I will check the pcv valve. Thank you for the advice.
I'm neither for or against catch cans, but I'm at 102,000 on my 2016 EB Expy without a catch can and no issues to speak of. The truck runs great. I've change the plugs twice, both times the old plugs were clean. I use full synthetic oil, do changes every 5k miles, and only use "top tier" fuels, none of my trips are short, every time it's driven it is brought up to operating temp, and though most of my driving is sedate, I do run it out to red line in 2nd gear once in a while when getting onto the highway to "blow out the cobwebs".
Thanks for the reply Loki. I bought it used with 34k miles on it and take it to the dealer for all maintenance (got the maintenance package for it). I doubt they'd stop doing maintenance if I install a catch can, but I don't want a warranty hassle if there's an engine failure (water pump, turbo, other).Mine has been installed since about 20K, and I am at 44K. It has been to the dealer for EVERY oil change!
I don’t get this problem in the winter with my Team RXP can because it separates the water from the oil and only catches oil. I’ve been relaying this info to all when trying to decide on which can to install. There is a benefit for the extra $$$.
