It's the arrows on the steering wheel.
All the way up is max distance, all the way down will turn it off.
Thanks! I’ll check it out tomorrow. As it’s not a menu option anywhere, that may just be the ticket. I wouldn’t have thought to push the adaptive cruise following distance buttons with the adaptive cruise off. Although the + and - button near the shifter turn the transmission display on and off, so it certainly makes sense.
Mines under pre-collision- distance indication. Again, this is on my 18 F150. That said, maybe I can look at ForScan to find the values for it.
hey everyone.. Just so we are all clear, most posts i have made anywhere regarding this feature start getting confused, like this thread.
I've explained what I'm looking for in a couple different posts, but most people seem to be confusing this with the collision avoidance system. So Trying to compile everything I can find around this particular feature, despite the fact it doesn't seem to be enabled on my vehicle currently.
First, the three similar systems are:
Adaptive cruise I think everyone is familiar with, so wont go into great detail, expect the fact it uses front radar to sense distance, and display that following distance in the console. Adjustable with the steering wheel button.
- Adaptive Cruise Control
- Collision avoidance system
- Distance Alert System
Collision avoidance system is what most people above are talking about. This is where the vehicle will basically scream at you that you are about to hit something, flash the HUD red, and big warning in console. Hard to trigger, although the case of someone turning in front of you as you approach their rear end does seem to trigger (at least it did for me). The collision avoidance system also includes the pedestrian detection, and I've never had that successfully trigger.
the Distance Alert system is what i am wondering if anyone has seen working on their vehicles. It is a part of the collision avoidance system. It uses the same part of the console as adaptive cruise, but only works when cruise if OFF (it uses the same radar sensors).
if the following distance gap is 09 -.6 seconds, it displays yellow, and if following distance is < 0.6 seconds, it goes red, and also apparently will flash a few of the red pixels on the HUD (not the entire bar, just like three of em)
The menu option to turn this feature on and off is supposed to be under the Pre-Collision menu, but on my vehicle it isn't there.
I've identified the bit in the IPC module which should enable this menu, and on my vehicle, the bit is turned off, Have tried to change, but unfortunately, the 2018 Exped has a new IPC, and currently it cannot be written to by FORScan
here is a Car thread also talking about the feature (Ford Fusion)
http://www.2gfusions.net/showthread.php?tid=4573&pid=126174#pid126174
and here is the IPC address.
values 8-B have FCW + FDA enabled (Forward Collision Warning, Forward Distance Alert)
So with the recent updates to Forscan, i was able to make this change to the IPC, and can confirm it does work as described in the manul.
it's in post #10can you post the code changes to make it work??
Gee, I don't have coolant temp in my '18 Expy Lmtd., just the gauge without an actual temp. Is this a setting somewhere? Thanks.
I'm also pleased that the IPC can now be modified in Forscan. In the table below, any idea what FFV means? The other acronyms seems to be explained in the post #10 except for FFV. I think I need option "B" to enable Forward Distance Alert but wanted to confirm what FFV meant.Thanks for posting this. I didn't know that Forscan was updated and could now write to IPC. Now I have everything like I want it!
I wasn’t sure what it meant either, but mine was set at 7 originally so I used B to keep them both enabled.
That's also an IPC setting:
also another one if you are usually travelling with a passenger / cold / remote start. you can heat the passenger seat too:
720-02-02 - 1st digit of second block:
Sorry newbie here to Forscan. I have downloaded the beta version, have the obdlinkEX cable and connected to the truck...just not sure how to get to the menu option you have screen captured above. thank you for the help!!
Click on IPC (AS BUILT Format) hit the play button GREEN ARROW at the bottom of forscan. Not my pictures below but this it what it should look like.
The remote start climate changes are in APIM
Read this: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
