03 xlt door ajar light always on
Butkie3248
So my door ajar light is always on and sometimes on the real cold days that we have had it turns off and stays off until it warms up and then its back on, what do i need to check?? Any help would be appreciated thanks....
Adam
Plati
Adam
Do the dome lights come on also, or just the red indicator light in the instrument panel?
Butkie3248
Butkie3248
All the lights stay on and the red light stays on. Ive just turned off all the lights off so they dont kill the battery.
Plati
That (turn lights off by spinning wheel to off) is what I was going to suggest. I used to have this problem all the time .... back when I used car washes. Stopped going to car wash, problem went away. Last summer I hosed the vehicle (03 Expy) off really well and it came back. I'd like to know what wire / sensor / whatever is to blame too but since I found a way to avoid it I threw in the towel. Some people say spray WD40 around door latchs.
Hamfisted
Ft Lauderdale
If the radio is ON and you turn OFF the ignition key, does the radio immediately turn OFF ? If so, it's most likely one of the front door jamb switches that's failed. Each door has one located at the bottom of the latch and you have to remove the door panel to access it. The two front doors will turn off the radio when they're opened. The rears do not. It's usually the driver's door switch that fails first, just due to the amount of use it gets. Be careful when ordering replacement switches because there is a different orientation for left and right sides.
Adam
Old Driver's side door jamb switch ( note crushed plunger ball ...) ....
Driver's side door latch removed from door for switch replacement... quarter turn to remove switch ...
RZ5639
Mass
If you haven't already replaced the switch shown above you can spray each door "plunger switch" with WD40 and push the switch in and out with your fingers. I have had several older 1st and 2nd gen Expeditions and this has happened a few times. It has always worked for me. YMMV.
Plati
i guess the switch is inside , no wonder i cant see it
