What brand/specs of a trailer hitch do you have?
armoredsaint
I've been using an old Curt from my other SUV with a standard drop, need a new one. I usually just tow a small 5x8 trailer for moving stuff
Thanks
Super Moderator
Super Moderator
Interested too.
How much drop/rise are people finding they need?
The receiver seems lower on our new 4th Gen vs the 17 3rd Gen.
Just curious what people are finding.
techdude99
US
I have a Weigh Safe 2-Ball Mount w/ Built-In Scale - 2-1/2" Hitch - 4" Drop, 5" Rise - 14.5K
I dropped it a couple inches and never needed the lowest setting. A pic is attached with my 18' Featherlite. I had to slightly change the weight distribution by moving the car slightly forward and dropped the height a tad more after the pic but this should give you an idea. It's not even close to the lowest setting.
Lou Hamilton
With stock suspension I use a traditional Curt hitch with a 4" drop. Keeps my camper at a level 18" front to back. My tongue weight is probably 450-500 max so no need for weight distribution. I forgot to measure sag, but it seemed to be minimal.
Unfortunately, COVID-19 has prohibited me from actually towing this year, but I did the initial setup back in January before we had a stay-at-home order. I do have sway control. That plate is not shown, but it basically is a second smaller ball to the right when facing the rear of the vehicle.
Lou Hamilton
Interested too.
Drop will be dependent on the trailer.
You will want to measure the height of the top of the frame at your axle. On mine, a 4" drop puts the ball head at right around 18", which is where I want to be on my camper. Good luck!
techdude99
US
I have Sumo Springs for the rear but haven't needed to install them. Ford's towing package with the built in sway control works almost perfectly.
Randy Schmidt
Illinois
I hate how the Expedition sags so much in the rear with just about any trailer behind it.
Deadman
I buy solid Aluminum receiver's for mine, so they aren't all rust after a couple winters.
techdude99
US
Same here. The only way to get around it are the Sumo Springs, to reduce spring travel, or a Weight Distribution hitch, to move some of the trailer weight to the front suspension.
PalosX
