Hamfisted
Ft Lauderdale
I re-read your initial post. The part about the gear shift lever not unlocking. It might be worth taking a look at the ignition switch itself. I didn't see that mentioned in what you had done already. I mean the electrical part of the switch, not the keyed part. You can take the top and bottom off the column and you'll see it. It's directly across from the keyed ignition switch. Pull the plug off and try jumping it and see if at least the dash lights come on, or you can unlock the gear shift lever as you normally would (brake depressed....) . Then you can try to bump the starter from there. The switch is only about $20 at Rock Auto to replace. You tried swapping in another relay into the PCM relay slot right ?
Here's a link for the 03/04 service manual if you don't have it already:
https://spaces.hightail.com/space/hoVVsN5P2A . The ignition switch is discussed on page 754 or thereabouts ....
https://www.rockauto.com/en/catalog...l-switch+&+relay,ignition+starter+switch,4700
stamp11127
Temple, Georgia
Since the starter cranked the engine when you jumped 30 to 87 that tells you the high current side of the starter relay circuit is working correctly. The problem lies on the control side of the circuit. Test time to find out where you have power and where you don't in that circuit.
03NavigatorGuy
03NavigatorGuy
Memphis TN
[/QUO
Yes, I have replaced all relays with known good relays to rule them out. I have the steering column panels off already. Do you know which pins I need to jump?
Hamfisted
Ft Lauderdale
Well, 4 is hot at all times, that's your supply line. 6 is your "run" line ( will give you dash lights...). 7 is your crank line when you want to start it. I wouldn't start it this way, but you can just check that things light up like they're supposed to when you jump 4 to 6 . The rest is up to you. If the dash lights come on when you jump 4 to 6 but they didn't before, I'd say your ignition switch is just bad. They're cheap.
ahiggins420
cola. sc
I have a 07 expedition that had a simular problem a few years back. It was parked running fine and just cut off. Would not crank, I can't remember if the windows or what other electrical stuff would or wouldn't work. The obd had no power to it. Took it to local mechanic who works on nothing but ford trucks and at first he thought it was the instrument cluster. Stayed in shop for a month and he found out it was a bad PCM. He replaced it with a used one and it has ran fine ever since. It happened around 100k miles and now has 170k.
rjdelp7
2000 XLT
NY
Youtube 'south main auto'. He did a video on a similar year ford f-150. He found a melted relay in the passenger compartment fuse box. It is a common problem.
03NavigatorGuy
03NavigatorGuy
Memphis TN
This is what I found. The wire to pin 4 is hot as it should be. When I jump 4 to 6, nothing happens, when I jump 4 to 7 nothing happens.
When I was testing the pins, I found that when I touched pin 1 with the tester light it caused the ignition switch to buzz, but nothing else occurred that I could tell!
03NavigatorGuy
03NavigatorGuy
Memphis TN
Yes, I like his videos, and I watched THAT video, even before posting here, as I was hopeful it would be helpful, but unlike him, I had already checked my fuses and relays PRIOR to starting any other investigating. It is so common a problem, I was sorta surprised neither he, and apparently, the other shop the F150 came from didn't check them first, or at least check them at some point, but nobody is perfect, certainly not me!
03NavigatorGuy
03NavigatorGuy
Memphis TN
I am ready to do that, I have done some, but PLEASE point me in the direction you'd go, and I will follow that lead for sure.
stamp11127
Temple, Georgia
Go back over reply #17, all the steps on how to test are there. The test light will provide a path to ground and complete the circuit to that point. When you get to a point where there isn't power, the test light will not light and the problem will be located between the last place you did have power and the spot you are currently testing.
You can change the order of the test points if you would like. If you start by pulling the starter relay and probing 86 in the relay socket, you should have battery voltage at that point when the ign switch is in "start" and the trans is in neutral or park. If not, then the problem is before the starter relay. Repeat test while whiggling the shifter.
03NavigatorGuy
03NavigatorGuy
Memphis TN
Test fuse 102 on both test points and follow the wire on the diagram
HAS
power.
Test the pin 4 light green/violet wire at the ignition switch
HAS power
Check pin 11 red/ light blue wire back at the central junction box with the ign switch in start
NO power detected
Check pin 3 tan/red wire also at the central junction box trans in park or neutral
NO power detected - rattling and/or moving gear shift - no change
Pull starter relay - check 86 when key is in start, trans in park/neutral
NO power
Hamfisted
Ft Lauderdale
So you don't have power getting out of the ignition switch if I'm reading the diagram right. They're cheap.
03NavigatorGuy
03NavigatorGuy
Memphis TN
It seems that way, I'll probably get/order one tomorrow. Just seems there is so much else that is not getting and/or putting out power!
stamp11127
Temple, Georgia
No power on pin 11 tells you there is one problem between the fuse 102 and the central junction box at pin 11. The ignition switch is between those two points. But you haven't proven it has failed yet.
At the plug for the ignition switch, jump pin 4 to pin 7 - this is the same as turning the ign switch to start. If the starter works the ignition switch is bad, if not then you keep checking.
Should it not work, leave the jumper on pins 4 & 7 and check pin 11 again for voltage.
"This is what I found. The wire to pin 4 is hot as it should be. When I jump 4 to 6, nothing happens, when I jump 4 to 7 nothing happens."
If this is correct then you have a problem between pin 7 at the ign switch and pin 11 at the cjb.
03NavigatorGuy
03NavigatorGuy
Memphis TN
At the plug for the ignition switch, jump pin 4 to pin 7 - this is the same as turning the ign switch to start. If the starter works the ignition switch is bad, if not the you keep checking.
Should it not work, leave the jumper on and check pin 11 again for voltage.
Jumping pin 4 to 7 did nothing! Also, I jumped pin 4 to 1 to see if something would happen, as I noted before that when I touched it with the test light, I could hear a buzzing in the ignition. When I did this something in the floor shifter started to smoke, if that tell you/us anything, other than don't do do it again!
stamp11127
Temple, Georgia
Smoke is bad! Very important to only jump the pins indicated or you may end up spending big bucks.
Pin 1 of which connector did you connect 4 to?
03NavigatorGuy
03NavigatorGuy
Memphis TN
If you are speaking of the ignition switch. I was looking at this one, it's supposed to be for 03-04 Navigators.
stamp11127
Temple, Georgia
If you connect pin 1 to pin 4 of the ignition switch plug, both are positive voltage. That will not do anything to cause you to let the smoke out.
Still need to jump 4 & 7 then check pin 11 and 1 at the cjb. Both should have power.
Also double check the wire color for each pin, anytime they don't agree that may indicate the wrong diagrams or the wrong connector.
