Going through this train wreck of a thread has been pretty excruciating. There is a lot of bad information here, and enough good to sort of make the read worth it. For some anyway. Couple of points:
- The PCV system has a "dirty" side and a "clean" side. The dirty side pulls the vapors out of the crankcase and introduces them into the intake tract to be burned. The clean side allows clean air to be pulled into the crankcase to provide some flow through the system. Putting a catch can on the clean side doesn't really get you anything. NONE of that has ANYTHING to do with DI, Turbos, or VVT. Although, the engineering and design work of the PCV systems on ANY boosted engine is more complicated than an NA engine.
- The 7.3L Godzilla engine is intended to replace the 6.8L V10 and the 6.2L V8's. There is no point in having TWO completely different engines for the F250 to F750 range. 6.2 was "OK" for the Super Duty 250-350, and marginal for the 450-550 trucks. Up until 2015, that was the top of the line. When Ford went back into the Medium truck market, the 6.8 went into the 650 and 750. Not cost effective. The 7.3 replaces BOTH. It was all about COST while getting economies of scale. This is ONLY about available GAS engines. NOT the 6.7 diesel.
- For the record, I have a JLT kit on my '16, and a Saleen separator on my '88 Stang with a 331 stroker. It doesn't have Di, Eco, or Boost!!! I'm going to put one on my wife's '19 Stang GT in the next couple weeks. It doesn't go out in winter!
