AKentPhoto
Just got an email that the JLT won’t ship til mid October... Any other can to check out?
Most of it is moisture and fuel.I wish I took a picture or video but I emptied the catch can and it had about a full shot glasses worth of oil in it. So I fully believe that having a catch can is a need.
Sent from my Pixel 4 XL using Tapatalk
So I own a 2007 Expedition Limited and I put the JLT catch can on it. Haven't emptied it yet because I just put it on. I am fixing to do a oil change soon. So I'll post a pic after.
So I own a 2007 Expedition Limited and I put the JLT catch can on it. Haven't emptied it yet because I just put it on. I am fixing to do a oil change soon. So I'll post a pic after. I am in the process of start a youtube channel which will start with me working on the Expedition. It was mistreated and I want to bring it back to it's former glory.
I think I did the same modification. Do the pictures look similar?After much study, I decided to go with the JLT for my 2018. She only has 7500 miles, so hopefully I caught it early enough. She will be in our family until she crumbles into dust, so my rationale is that at worst I will keep my intake cleaner for no reason. At best I could save a couple of head replacements or cleanings and have a better running engine long term. Total was under $200 with the can extension. When installed I couldn’t get the engine cover to sit right with the hose routed from the PCV toward the passenger side. There just isn’t room for that hose. Then I noticed on the bottom of the engine cover there was an “imprint“ of the PCV connector and hose going toward the front of the engine. This is how the original hose is routed, toward the intake. So I tried routing the JLT hose forward, and I found the clearance I needed to properly seat the engine cover. I made a small half moon cut on the front of the engine cover to accommodate the hose. The rest of the install was very easy. I then did a 250 mile trip towing a 2000 pound covered trailer. With a drumroll and an audience I pulled the catch can and... not a drop! I verified the hoses were routed the correct way, then felt the screen of the oil separator and I did get a haze of oil on my finger. I won’t check it again for at least 1k !!
Big thanks to all the recommendations and input on this topic. And a shout out to JLT. I was very impressed with the manufacturing quality of this item, and their outstanding communication.
Drivers side PCV?Well, no, but it’s the same idea. I think yours looks better! My objective was to get the engine cover to be in the same position that it was in prior to the catch can installation. I ran the PCV tube forward, toward the radiator. It seem to clear everything underneath the engine cover, but as it routed underneath the front lip of the cover it pushed up on it slightly. I can post a picture tomorrow. My modification shows, and criss-crosses the hoses. Yours would not show, with better more sensical routing. Does the cover sit flat now?I think I did the same modification. Do the pictures look similar?View attachment 38363View attachment 38364
I just got the URP / 5Star tuning one, but it says I need to drill a hole in my charge pipe. Anyone have experience with this for the expy or using it?
It looks a bit complicated for a simple catch can install. Any input is appreciated.
The UPR kit is MUCH more involved, and overkill in my opinion. It will catch more than the JLT, but at a much higher price tag, and more invasive install.
Totally agree, but I already ordered it not knowing about the drilling piece. So what I will do is not drill my charge pipe but order the S&B intake from them and drill the intake pipe. This way I can clean it easily and not have to worry about damaging factory components or have to remove anything. Gonna set me back $1500 for this whole set up, but I guess I’ll just go through with it now. Overkill and all LoL.
Thank you for the feedback [mention]LokiWolf [/mention]
I would like to see a 5K mile oil analyst without the catch can and then one with the catch can after another 5K.
So a bit of Clarity...
A catch can will have ZERO change on the analysis of your oil. The point it to prevent gunk from entering intake and leading to buildup on the intake valves and surrounding area. The oil vapor is the issue, not other things ending up in the oil.
There are supposedly some oil formulations that minimize the buildup. Not sure how, haven't investigated the chemistry of it. I know some Audi/VW guys running one of them, and they say they have seen a difference in buildup.
Check interval should be based on miles, environment, and use case. I can easily go the oil change interval in the Summer, in the winter, because of additional water vapor, it is close. This is based on my previous 3 EB power vehicles. Idling will increase the vapor. Hard accel seems to increase what is being collected also.
If you are doing a bunch of miles or a bunch of idling, then the time interval will be shorter.
Hope that helps!
