13-14 3v 5.4L engines. Cam phaser or Rocker issues?
1exped
NY
Do you have a part number for the sender part?
Motorcraft SW1547B Oil Pressure Switch
Problem though is you are going to have to know how your oil pressure gauge works. The cluster may just move the needle to the center unless the sender is open. For something as new as these trucks, you may have to buy a kit and gauge.
07navi
Mt.Shasta California
That old pressure/switch sounds like an easy fix but you really need to know exactly what your pressure is.
rwmorrisonjr
Memphis, TN
Did some research, and it most likely won’t work due to the electronic dash design in our trucks. Aftermarket gauge it will be!
Lynnii2
Los Angeles, CA
I have 2010 Ford Expedition Limited 5.4L with over 205,000 miles. I will say at this milage you have to change the oil every 5,000 miles and use 5w-30. I would definitely buy the extended warranty to cover engine and transmission just in case something in the future happens.
07navi
I agree with everything but the warranty.
