lefty hack
RCI off-road skid plates... engine and transmission install today. I tried to get the second plate to set under the front but wasn’t able to. I had to leave. I’m getting back under to try something else.
The F150 2009-2020 works as has been discussed here. Eco boost owners lose out on one drilled hole on each of the 2 Z brackets that mount the front plate. Use a speed clip per side in the hole forward of the inter cooler to mount the Z bracket. Other than Everything lines up perfectly.
