Miztertorres
Hello, just a quick history .
Last week , I changed the intake upper and lower gaskets, Throttle body gasket, Waterpump, Thermostat, Fan Clutch, all sparkplugs , replace orings on injectors, fuel pump and fuel filter. I did loosen the EGR tube to get to the plugs and injectors.
Now that everything is back together , I have a ticking, tapping , knocking sound that I cant trace.
I dont know if it because i loosened the EGR tube, if its a valve, lifter, compression etc....
The check engine light did come on saying PO0153 ( o2 sensor circuit slow response bank 2 sensor 1) this was a pending code prior to all the work and there was no ticking /tapping noise.
I decided to do all this work because i was getting bad fuel milage.
I dont know if a o2 senor can cause the ticking noise which gets louder and more repetitive when driving .
the engine runs smoove doesnt shake like a misfire, but does vibrate and stumble a lil bit while driving
PS all the COP are 6 months old with the except 1 of the them ( # 5 cylinder)
i check the ohms on the injectors and all are in specs.
HELP ......
HELP ......
