Cam Phasers or Turbo Wastegate Rattle?
patterrr
I'm so sorry for starting another thread on this topic... Ever since I bought by 2019 Expedition max there has been a rattle from the engine compartment on cold start. I have literally spent hours reading these forum posts and watching YouTube videos. From what I learned, I self-diagnosed it as being wastegate rattle. I'm totally not qualified to diagnose, but there you go.
Anyways, I took the vehicle to my Ford dealership today to have the failed center brake light replaced under warranty, and I mentioned to the guy that there's a rattle in the engine compartment on cold start; if they have it all day and start it after it has cooled down, can they check it out? He said right then it's cam phasers. I asked how they know that the rattle isn't the electronic turbo wastegate, and he said that isn't a possible rattle, but "cam phasers go out on all these vehicles, so I'm sure that's what it is". He then called me an hour later and said the rattle is definitely from cam phasers, and he wants the vehicle for several days to replace them. Odd since the vehicle didn't even have time to cool down enough to replicate.
It's a bummer how experience can vary from one dealership to another; some complain that their dealer refuses to fix the problem, while mine is so anxious to jump on it. I'm thrilled they want to fix my problem, but my question is: HOW DOES ONE DETERMINE WHETHER THE RATTLE IS CAM PHASERS OR THE WASTEGATE? I'd love to feel confident that it has been properly diagnosed rather than diagnosed based on assumption because I really don't want the engine opened up if it's a different issue, and the guy I spoke to did not instill much confidence for me.
I need the vehicle tomorrow so told them not to start the work and will schedule it for after boating season ends when I don't need the vehicle. He told me that's a terrible decision because they could go out any minute and leave me stranded. I thought that was odd as well because from what I've read in other posts, Ford doesn't even think it's a problem that needs fixed.
Anyways, here's a sound clip but not very good... The rattle in this clip sounds so much worse than it actually is. Standing next to the car you only notice it if you're listening, and it just sounds like an exhaust hanger is loose.
https://drive.google.com/file/d/10TqS3epotFVIQo_Lv3-puTUzAL5RyKfg/view?usp=sharing
BMW2FORD
CT
I couldn’t open the file the listen but the phaser rattle is up high and the front of the engine. Wastegate rattle isn’t as bad of a sound and is low and toward the back of the engine and usually heard best at the back of the front wheel. In the field, getting the car to where the customer says they hear the rattle and using a mechanics stethoscope or long screwdriver to the ear is normal practice. If that doesn’t work, disconnecting systems to alter the noise or visible inspection would be next.
keny01998
Arkansas
The problem is usually from the cam phasers. I had mine replace back in August and my engine has been quiet seen. I have 2019 XLT 4wd with only 23k miles. The dealer said they saw many F150 with same issue and they got the parts within a week.
P
patterrr
I picked it up yesterday (turns out they didn't even have parts to fix the brake lights so only got diagnosed), and they said the parts will be here within a few weeks to do the cam phasers. I plan to wait until December when I don't need the vehicle. How long did it take ya'll to get yours fixed? I did ask the service rep specifically how they diagnosed the issue, and he said that when they hear a rattle they start with replacing the cam phasers...
aggiegrad05
North Texas
If the rattle is harsh and goes away after 2-3 seconds, it's cam phasers.
If it is softer and lasts for 60-120 seconds, it's wastegate.
aggiegrad05
North Texas
I just listened to your file...I think you have both the cam phaser issue (that's the harsh rattle in the first couple seconds) and a rattle in the wastegate (that's the soft rattle that continues after the harsh rattle at start-up stops).
Samuel Street
United States
Here is something to try. While starting hold down accelerator for 8 to 10 seconds, this will prevent the engine from starting giving a chance for the engine to build oil pressure. If no rattle its phaser issue.
Thomas Hardesty
Naples, Florida
Mine has the 3 second rattle on cold start up as well. I change my oil every 3-4000 miles regardless! I’m not certain that the phaser rattle isn’t really that harmful? I know the Dealerships will replace them all day long if you pay them! From what I have researched, to replace them the entire top end and many other parts need to be detached to perform this (FORD F-UP), cam phaser change, and the cost is over $2700.00? I have 92,000 on my vehicle, and baby it all day! So I’m as confused as the next guy as to the truth about changing these out? Seems like a Class Action lawsuit needs to be filed to get Fords attention?
Thomas Hardesty
Naples, Florida
Thomas Hardesty
Naples, Florida
DGeis
Cincinnati, OH
Mine is getting worse and worse. My shop did the cam phasers and then replaced the entire catalytic converter.
WALoeIII
You have both.
You can reach in (when cold) and push on the wastegate actuator to stop the rattle.
5280tunage
colorado
You have both.
And just remember, it's a ****** design, it will be back. I had both turbo's replaced (since the actuator and spring assembly replacement doesn't fix the issue, it's more internal). The noise has been gone for about 10k miles but I've heard it a couple times lately (which tells me it's going to be back no matter what). Funny, my family had a mid 80's subaru with a turbo that didn't fall apart in 12 years with 200k miles. But things get better with time and a 500% more expensive design, assembly, and engineering right?
P
patterrr
Follow-up to my OP. Ford did the cam phaser replacement and the rattle did not go away. The rattle didn't change at all from before the work to after, which still makes me wonder if I ever had a cam phaser issue.
@WALoeIII I'm not exactly sure what I'm looking for, do you have a picture of what the wastegate actuator looks like? I'd like to try your suggestion to push on it to see if the rattle stops.
Bmac1955
Southern Cali
I purchased my 2019 Expedition 10/27/2021 used from a Ford dealership with 32k. It was a lease from the dealer. 202a package and 20 in factory colored rims. Heard the rattle upon cold start up and concerned. Had a service Tech adviser bring over a engine tech and discussed the noise I had heard upon start up (cold ) and told me more than likely Cam Phasers. So Nov. 1st bought it in with an appt. To eliminate any questions I recorded the Engine noise after a two day set. They wanted to do a Shudder download and I created feedback against that. I did my homework with paperwork stating the issue is with the Phasers and that is in accordance with the recall. The vehicle still is at the dealership waiting for it's position in line for the repair and it is Nov.12th. Along with the purchase I bought a Ford Protect warranty 96 months or 128k. It is what it is. I have other vehicles to drive but just want the issue fixed. I have dealt with idiot sales people which were kids to service personnel that will lie to your face. Some things just don't change in the auto industry. I had that experience back in the late 70's while working for Ford. Got out of it, I had a conscience and went into Construction. Way more Money and retired from it. Pensions were well earned.
Bill Schell
Montana
Clearly FMC has no intention of doing the right thing for their customers. They are simply running out the clock. My VCT system was replace at 50k and I still have the light "tick-tick" at start up. This with supposedly "new design replacement parts". Thus far no warning light and it runs great. I'm now just hoping not to have to repeat this service before I unload the rig.
Bmac1955
Southern Cali
Just an update on my Cam Phaser repair. received a call 11/12 from the Fire stopper at the Ford Dealership. Apologised for the delay (2 weeks). Due to the repair work being done. She also informed me that they were waiting for a part and would have the truck on Monday. Curiosity set in and I asked what part. She told me a Valve Cover..............For the life of me I can't understand the need for a Valve Cover replacement along with the cam phaser replacement. I didn't read that on the service Bulletin for parts replacement. I will get lied to again on Monday or Tuesday i'm sure. Stay tuned..............
2018ExpyPlatinum
Arizona
I'm so over this whole cam phaser thing and the wastegate thing. I really don't care anymore. Fix it, don't fix it, let it blow up, whatever. I'm also done with Ford. Won't buy another for a LONG time if ever. They have turned their backs on all of us, so screw them.
Interestingly though.....I parked in the street the other day after running some errands because I wanted to blow out the garage and the driveway real quick. Walking back to the truck (which I left running and the engine was warm) I heard a continual ticking. Some what fast, tick, tick, tick, tick, tick. Any guesses on what that is? Almost like the low oil or bad valve tick from the 70's. Thoughts?
