Another 5.4L tapping noise thread (sorry)
Dustin Gebhardt
Tulsa, OK
I don’t think that anyone has mentioned the common exhaust manifold leak on the passenger side. It would make a ticking noise upon startup that often goes away or gets much quieter as the engine warms up and the gasket/leak seals itself temporarily. I had a pretty significant ticking noise and I replace my manifolds 2 months ago. My passenger side exhaust manifold had a 3-inch u-shaped crack all around the hole for cylinder 4. New headers with a good gasket fixed the sound and my fuel trim levels for that side now match my drivers side fuel trims.
Goofy173
Ky
sounds like you've got a bad roller follower to me. I personally would not ignore it, if it spits out the follower you could drop a valve and that would mean new engine time.
Unless the roller sticks just right its not gonna hold the valve down. Normally if the roller come out it would just keep the valve from dropping at all. The valve will stay up because of its spring.
Goofy173
Ky
I thought my tick was a phaser. While a phaser spring was broken, the tick is still there so I'm sure it's a roller on the rocker/follower. The phasers and chains did at least fix my massive power drops while accelerating. Phasers and chains cost me $1700 but he was slow and had it for just over 2 months. Good price but I won't take it there for the roller.
Motorcity muscle
Motorcity
Have to go back to the original post, after an oil change. If there was no noise before this and the truck just sat for two weeks, would have thought you would of heard some noise before the oil change if a problem was starting. Would not be the first time a problem was created by improper oil change. Did you check the oil level after you had it changed?
ssmock
Kansas City, KS
I was reading this thread and was going to comment on the exhaust leak. My Expy is 2014 Limited with HD Towing pkg. Had the left bank manifold crack and I thought it was a lifter. Luckily it was still under my extended warranty. Broke the manifold towing a car trailer across the mountains and put too much stress on it at 90K miles. Now have 124K miles on it and getting the same ticking noise out of the right bank. Notice it on startup but goes away in a few seconds. Out of warranty now so don't know if I want to go to the expense of fixing it. The dealer had three bolts break, said if I was paying it would had cost $1,500 or so because of the labor. Not too bad yet and I don't think it's hurting anything. Love the truck but thinking of going to a nice used F250 if the price ever goes down enough to be able to afford it. Pricing is way out of sight right now. Can't believe what the dealers are asking for a truck with 60 to 110 K miles. I would check for the cracked manifold and it does sound like a lifter ticking.
Same deal, either getting a new Expedition or a Suburban when this nonsense settles out. I’m tired of rust and repairs.
steeltoe
steeltoe
brooklyn
No noise before the oil change and definitely no issues with power loss or fuel efficiency. Passing on country roads was a breeze before and I'm afraid to even try it now.
Oil change was at 110k, noise started at 112,500 and I'm at about 114k now. My mechanic did an extra oil change for free a little while after the noise started but that didn't fix anything. Oil pressure and levels were good are good, but I didn't check what kind of oil or filter they used for that 110k change.
Brons2
Austin, TX
Tell that to the guy that owned this engine that is now junk:
2011EL
Houston
I was reading this thread and was about to make the same comment. I just watched that video this morning. Read thru the entire thread to make sure no one else shared it already. You beat me to the punch. lol
reneb64
tldr: My Expedition clocked 113k miles and just started making the ticking noise. I know this comes up all the time, but does anyone who solved this problem have advice on what to inspect or replace first?
Bought my 2012 last November with 103k miles on it. Good service record, my mechanic gave the powertrain a thumbs up.
Got the oil changed at 110k, and then parked the car for two weeks. When I started it back up the engine was making the tapping noise. Assumed it was the lifters because it sat for a while. Took it to my mechanic who agreed it was probably lifters and said maybe whoever did the oil change didn't use high mileage oil. He replaced the oil for free but the noise is still there. At this point he said I was probably gonna need to take the engine apart to know for sure, otherwise I'd just be wasting money. He suggested I bring it to a friend of his with a bigger shop that works on Ford fleet trucks.
I've read that it could be:
Since the noise started I've noticed a super inconsistent issue with power loss when accelerating, usually between 1st 2nd or 3rd gear. Usually doesn't happen on the highway or from a dead stop. More noticeable on back roads when I slow down for someone turning and then gas again. Also seeing 13-15mpg highway, compared to 16-18mpg before the noise. This makes me think spark plugs, but the fact it's so random makes me wonder if that's an unrelated airflow sensor issue or something.
Other info:
  • Check engine light has never came on.
  • Oil pressure is normal.
  • Noisier on the passenger side.
  • Increases speed when I rev the engine.
  • Pretty loud when I start up. Gets quieter after driving, but not always.
  • I live in Brooklyn, so it sees some city miles. But I mostly use it for road trips and off-roading on weekends.
Saw a lot of posts here & in F150 forums with people saying that they just ignore it. Some other posts saying the engine is gonna blow up. I kinda don't care if the truck sounds busted, but I definitely don't want to be running it into the ground. Especially if the engine is gonna throw a spark plug when I'm 15 miles from cell service.
Before I start throwing parts at it, what should I try to fix first? Most likely issue? Cheapest fix to try? Spark plugs & coils? Open up the engine to check the lifters and camshaft? Buy a BlueDriver and check for codes? Anyone have a link on how you fixed this in your truck?
Having the same exact issue. I had an oil leak, timing cover off, so i had the mechanic replace timing components, VCT valve, water pump, tensioners, guides, phasers, but he inspected the roller followers and sad they were good. 10-15k miles later (149k), the passenger side rear most is making noise. Slight tapping. I also noticed lower power during first to second gear shift (during acceleration). cleaned MAF, plugs were changed a couple years ago, did you ever figure out the problem? suspect roller followers.
mr_dave
MN
That sounds exactly like how my roller follower issue started. Tapping noise from passenger side, down on power, down on MPG. Had all roller followers replaced with the updated version plus a new passenger side cam and everything has been working well since.
mr_dave
MN
How is yours holding up after all that work?
It has been perfect since the major surgery, about 25k miles ago. I actually just listened to the heads a couple weeks ago with a mechanic stethoscope and they sounded great! The only other issue I've had since then is alternator bearings, easy fix.
