After market struts/ shocks
X BRONCO OWNER
US
So my rear struts blew out and leaked all over my driveway. Im out of warranty im so I wanted to get Bilstein 5100’s but they are on back order until at least mid july. The only other struts i can find are KYB. Has anyone tries these or should i wait a few months for the Bilsteins or does anyone know of another brand out there.
Squark
NC
I ordered Bilsteins last July and they still haven't arrived. My ETA was Sept, then Nov, then Jan, Mar, May, and now July. I hope they actually show up by then, but I'm not holding my breath. I had 6 factory shocks leak. They're pretty terrible. Since yours are completely blown, I would replace them with KYB since you can get them right away.
Wangle
Des Moines, IA
My shocks lasted 8 years/100k miles in my 76 Chevy Vega. Then I sold the car, bought a Cavalier and swore off GM forever. Never lost a shock though. My 2003 Expedition had a leaky strut at 165,000 miles. Pretty good! My 2018 Expedition, purchased in January 2019 new, lost both front shocks with less than 15,000 miles. I consider myself lucky though, because at 18,000 miles I have not lost my rear shocks, YET. KYB is a great product. You need them now, so go ahead and use the KYB. Another option is to replace with the OEM Ford shocks and hope they last you until July when the Bilsteins are available.
Seriously, it boggles my mind that a manufacturer would put junk shocks on their flagship vehicle and not fix it with a recall. So embarrassing.
Backinblack
Buffalo, NY
I had one each front and rear replaced under 3/36 warranty. Now another front is leaking and not covered under extended warranty, dealer wants $600. I have never done shocks myself, any recommendations? On a 1-10 scale of difficulty? Thanks.
Gumby
Beaumont, Alberta
Replaced my rear CCD shocks because they were leaking. 2k job at the dealer in Jan 2021. I think they are shot again...
JasonH
Houston, TX
I would say a five ot six for the rear. It's relatively straightforward if you can get the spring compressed and the shaft nut loose. Having said that, issues can arise. My passenger side was easy then I spent hours on the driver's side because the lower bushing would not let go of the bolt. After fighting with the bushing, I finally set it on fire and that did the trick. I haven't done the front, but there are a few more parts to undo so its higher than the rear. For calibration, one would be an oil change, ten would be internals.
Soliyou
OK
KYB manufactures OEM struts for Toyota (or at least used to do). They have been doing great on my minivan over the past 8 yrs and 90k miles. So I would go for them with no doubts.
Regarding the replacement difficulty, I would say 5/10. You can rent a spring compressor from Orielly’s. Or you can take your assembled strut to a machine shop and ask them to swap the shock absorbers. They will charge you 30 minutes of labor.
8131full
Las Vegas
is there a way to know if my fronts are bad if they're not leaking? Every day when I first start driving, there is a slight knock from the front left when I hit the first bump. But then never does it again. Ride quality is fine.
Squark
NC
Mine does this on both sides. I replaced my shocks with Bilstein 5100s and it still does it on the first few bumps in the morning. I haven't investigated further since it did it before and after the replacement.
sharprd65
