Let's See Those Lifted / Big Tire Gen 4s!!
sjwhiteley
Kentucky
No support yet. I do not mind the spedo off as long as you remind yourself it reads slower than you are actually going.
In the long run you will have a lower odometer reading for same miles driven as if you had stock tires.
Do you monitor your mileage? How much of a change did you see in the MPG? I went to slightly bigger tires and saw a dramatic decrease (1-2 mpg). I don’t think it’s right, though, but haven’t done an actual calculation.
GixxerJasen
DFW TX
295/70 R18 Toyo Rt Trail on stock Timberline rims and suspension. Didn't have to trim or move anything. Haven't noted any rubbing with normal driving. Thank you to earlier posters with their setups.
Wow, I don't think I ever paid too much attention to the stock timberline rims but those look really good. I'm happy with my selection because it matches my paint better but if I'd gone with my other options of a black or white Expedition, those would be my choice. Looks great!
leirej
SoCal
Im seeing about a 2 mpg decrease. I'm thinking it's because of the speedo not being accurate. I was able to recalibrate it this morning through forscan so we'll see if it gets better but i doubt it will improve by much. I'll do a hand calculation on the next full tank.
LazSlate
Arizona
Agreed. Bigger tires you travel further per rpm so while no doubt there is a decrease in mpg due to heavier wider tires I do not think the mpg loss is as great as it says.
GixxerJasen
DFW TX
You will definitely lose some mpg to rolling resistance. When I did my swap. the tires were slightly taller, slightly narrower and the whole package was much lighter (22" wheels to 18" wheels) as I weighed them both. On paper that should have resulted in higher mpg but I still lost mpg. Presumably due to AT tire not having as good of rolling resistance even with calculating the slight difference in circumference.
GixxerJasen
DFW TX
That always looks so much better. Wish they hadn't encased chrome inside the headlights.
litaz1
hawaii
Finally swapped the factory 22s (285/45r22) for 18s from KMC with 35mm offset. I've always had good luck with Nitto Ridge Grapplers, so that's what I wrapped them in.
New tires are 275/70r18 (33") and fit great with no rubbing.
Chrome delete is up next for the weekend project.
That looks awesome!
GixxerJasen
DFW TX
Did you paint your decals black?
If you are talking about the raised lettering, they come that way from the factory on the Stealth package. However, somehow stealth still meant a chrome beltline. Stupid.
NTY18
Alabama
That looks awesome. Love the look. Just bought some Raptor Beadlocks for my wife's 21 FX4 and wondering if I can fit 295/70r17s. Not sure if the FX4 and Wilderness have the same suspension as far as height. I've read that they do and that they don't. I want to install the largest tire possible without a lift. I know it's been discussed a bunch but looking for a definitive answer.
Ediz4riz
Cashiers, NC, USA
2018 Limited Max HD
Lift : Bilstein 5100 F150 struts bottom ring/5100 Expedition rear shocks top ring
Tires :Toyo Open Country AT3 275/65r20 (34.1 inch tall 11 wide)
Rims: Factory 20" with Rough County F150 2" spacers
Does it poke? Yes a little
Does it rub? Yes front tires in front and rear of the tire.
need to pull/adjust fender liners back.
View attachment 41555 View attachment 41557 View attachment 41558 View attachment 41559 View attachment 41561
IMO one of the best looking I’ve seen. Perfect combo!!!
FabLab05
Trying to make what ford won’t!
2023 Timberline running Gen2 Raptor upper and lower control arms, tie rods, Fox. 3.0 non live valve shocks i mounts using the Camburg Raptor conversion buckets. Rear consists of the stock Timberline strut with a machined 2” spacer and longer control arms to center the wheel and tire. 37” BFG K02s on Raptor 37 package wheels. BajaForged roof rack and KC Pro6 lighting. Next is to modify a set of Raptor fender flares to fit!
AKDV
New Mexico
Awesome setup. How does it work and is there anything you would do differently?
FabLab05
Thanks! So far it’s working great! Currently only thing I’m going to change is dropping the front lift height by 3/4” and re-gear the diffs. The ride is a bit stiffer which i was looking for, stock ride was a bit squishy for my liking.
ak49
Alaska
Where did you find longer control arms? I wouldn't mind centering my rear wheels after my ReadyLift.
