Suspension issues??
tri650
St. Louis, MO
I just picked up a 2017 Expedition Limited and I am having some really wonky suspension issues. It has 82K miles and in pristine condition.
I first noticed that it really wallowed over bumps, meaning it was like a trampoline in terms of the bounce. Then after going over some rough pavement on the highway at about 80 the whole back end felt like it was going to break loose. It lost contact with the road and started to shift sideways. I noticed this a lot as I am just getting back from a 2000 mile trip to North Carolina. Some rough highway roads and it was not fun. Felt I was battling the steering the whole way as it bounced down the road.
I am getting the alignment checked, and I also read the back end issue could be cured with a sway bar. I had a 2010 and had no issues. This has some issues and really not fun to drive in its current condition. Any thoughts or similar experiences?
JasonH
Houston, TX
Rear struts are toast. Mine launched passengers in the third row when rebounding over sharp bumps when they were done. Replace those and enjoy the ride.
ssmock
Kansas City, KS
Had the same issue on my 2014 with 150 K miles on it. Replaced the front struts and it rides like new. Big difference.
T
tri650
St. Louis, MO
Thanks for the info. I have read a few different threads on this and Bilstein seems to be the strut of choice. Any opinions on this option?
rwmorrisonjr
Memphis, TN
I've been running Bilstein 5100s since 75k miles, still ride like new at 176k.
JasonH
Houston, TX
I went with KYB for my rears. Didn't need height adjustment or more stiffness. My E tires already made the ride stiffer.
clf34
Indiana
I just posted about a similar suspension issue on my 2016. However, mine does not act like a trampoline over bumps, rough pavement but when turning I am rocking like a boat. Hoping to get some answers here on where to start looking. Maybe it could help your issue as well.
Yupster Dog
Moderator
Many Members have said the Hellwig sway bars/stabilizer bar (especially the rear sway bar) help those issues.
Put Hellwig in the search box top right of this page to find many threads/posts on the subject.
clf34
Indiana
thank you!
JasonH
Houston, TX
If it's rocking that badly, it's probably worn struts. The handles fine when the suspension parts are in good order. Struts wear out, the sway bars don't (apart from the rubber parts). How many miles on the vehicle?
T
tri650
St. Louis, MO
I had the alignment checked and it was out of alignment in the front - both wheels. Not sure that really changed anything I could notice in terms of ride. They did an inspection of the suspension and did not see any leaks.
I just ordered the Hellwig rear sway bar. I'll see how that works.
