Gorilla Nuts
ryoung57
Missouri
Are these correct? It’s the part number that matches, but the seat seems much smaller than stock.
GAU-K6TS-14150BGR
BMW2FORD
CT
For sure not the right ones. There is a part from Gorilla that has the wide seat like the lug in the right (believe they call it the 45 degree or wide cone) which is what you need. The smaller cone will dig into the rim.
HILLY
Greenville, SC
Unless you're really going for the spline, these are what I got a few months back to replace my swollen nuts. I originally bought a set from somewhere that had a smaller surface area like the ones pictured above and after doing a test install it was a definitely no-go with the lack of surface area. The thread type for reference is M14x1.5.
GixxerJasen
DFW TX
Nice find, good price.
Tuck
South Carolina
Gorilla Wheel Locks 96641BDX. Double check these. I think they are the ones I got for mine but don't have the package anymore. I'll see if it's on the lock code card when I get home.
GixxerJasen
DFW TX
Good stuff. The ones in this link are a little longer than the Ford ones but not annoyingly so.
Before:
After:
HILLY
Greenville, SC
Dang. Literally just ordered myself another set this morning for the "new" truck.
They still worked better the most of the others I came across.
GixxerJasen
DFW TX
Yea, saw your like in my notifications and figured I'd come back in and toss up a long term update in case I could head you off. You are right though, not a lot of good options out there, and I suspect the black ones will probably all do the same. I'll post up a few pictures after I go get it from the shop for the stupid expensive cooler hose replacement it just had to have done.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
So you got about a year or so out of them ?
That suks wallah, I would have expected them to last longer....
When you had your tires removed/replaced, have you been telling the tire techs to NOT use an impact wrench to install them with ? That may have helped them get less scratches/rounding & therefore less rust...
Dice Roll
Craps Table
Glad I went with the chrome ones then. I was kinda bummed I didn’t get the black. So far the chrome is holding up.
GixxerJasen
DFW TX
Haven't had them done professionally yet, though it's due. The "Tire guy" is me that put the nuts on and my tire guy is lazy and has an impact for a reason. :D
Yes it's disappointing, but not too noticeable unless I get up close like for the photo, and still looks way better than nasty chrome.
