2023 lane assist not green/red
ROBERT BONNER
Denver, NC
I'm not sure where "Tifton" is, GA, maybe? At any rate, these systems have to see well painted lines on both sides of the lane. If they don't "see" those painted lines, they won't work (they'll go grey). That means that in NC that they work 110% of the time, because in NC we have something called "road maintenance" in MI, it means they work about 35% of the time, because they don't have anything remotely resembling "road maintenance". I'm unsure about the roads around Tifton. In the snow or heavy rain, they rarely work. They won't work on gravel roads or where the lines are worn so much as to be difficult to see. They will also periodically go grey when you pass intentionally unmarked areas where there are merges or other intersections.
rugedraw
Miami, FL
Well, just changed that value to a zero and took my truck for a drive, and LKA and LC worked as it should. Lanes turned green when I reached the right speed and turned red if I started veering out of my lane. Whatever the issue is, it is not that. I'm out of ideas.
J
justinj229
tifton
Interesting, I wonder if I'm having a faulty camera issue?
