Circle patch roof of my expedition !?
Canada
After 3 year of ownership, I just spot that. I am wondering what could this be ?
Yeah I know it's rusty, i will fix that soon.
Bought at dealership, this was never disclose !
Year, make and model?
How did you determine the defect was present when you bought it three years ago, but just now saw it?
L
Canada
It 2020 ford expedition max platinum bougth in 2022.
it located pasenger side around the middle, just next to the roof rail. I did not saw that when i bought it, i would say it's quite well hidden.
Also the puck was probably black and start rusting so it's more apparent now. Even on the running board it's not that visible.
I was doing maintenance on my travel trailer "next to it" and been higher it caught my attention.
My hypothesis is probably had some sort of light bar installed and they removed it, but since i dont know the history of the vehicule i was quite surprise.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Well, whatever it was, that's one helluva sloppy-assed patch 'em up job :Pshyco:
I'm just guessing here, but that looks as if it could have been where a police/fire dept flashing/rotating light was mounted, or perhaps a satellite dish or some type of antenna....
I can't really understand how you did not notice it when you bought it, but obviously you did NOT look it over very well prior to driving it home....:oops::Grenade:
L
Canada
Your comment make me think could it be to allow a magnet to stick, since the body is all aluminium as far as i know ?
I will look more closely if it seems to be mounted with 3M tape or something similair.
Like this :
2025-06-22 23_33_18-magnetic antenna mount for aluminum truck at DuckDuckGo.png
Rob6805
Like this :
The pic does look like it's been stuck on the roof as opposed to a "patch" for the roof. Try and heat it up a bit and pull it off.
bb37
Member Relations Specialist
Indiana
Rugged Radios, who caters to the off-road crowd, sells these disks for mounting antennas on aluminum or fiberglass roofs.
Fizzy
Alberta, Canada
That was my thought too when I looked at it - it's sitting proud of the surface like something stuck to the roof panel, rather than a patched hole.
I would not try heating, yanking, or prying on it. I would visit a local bodyshop and see what they think. Even if it's just some professional opinions. Even better, maybe they'll get that off and buffed for a couple hundred bucks. Better that than you crying into your poutine because you screwed your roof up.
GixxerJasen
DFW TX
Heat and fishing line would be the first thing I'd try. Too easy to screw something up with prying, but if it's got the right adhesive, the fishing line should pop it right off. I've used it to make short work of factory installed badging that didn't have locator holes.
JamaicaJoe
Oviedo FL
I am in the radio biz. There are never ending questions from folks (usually ham radio dweebs) wanting to put antennas on their roofs with a magnet mount or other horrid contraption. The professional way is to drill a hole for an brass NMO mount (Motorola) as it seals nicely, works on aluminum and steel, works well, and if or when you are done with it there is a rubber plug or simply a cap for the NMO mount. Instead they slap a mag mount on the roof and it scratches everything, moves around, pops off and bangs the glass and sides. In this case, because of aluminum roof, they have glued some steel plate and have created god knows what kind of damage and corrosion. Try a moderate amount of heat from a hair dryer and slowly lift saying a prayer to Sherwin Williams.
JamaicaJoe
Oviedo FL
Dental Floss is also an excellent tool to slide under.
